WTB 1972 4x4 350ci misc parts
Hello everyone!
Need your help in finding some misc engine stuff for my 1972 GMC Jimmy 4x4. Looking for the following factory original items for 1972 350ci. -Valve covers -Oil fill tube -Timing chain cover for a 8” balancer (Timing tab spot welded to cover) -Fan with clutch -Ram horn exhaust manifolds (can be drilled for smog) -Passenger side spark plug heat shields If you have any of these items please post pics so I can see what you have. Thanks for the help! Eric |
![]() Join Date: Feb 2012
Re: WTB 1972 4x4 350ci misc parts
I have a set of manifolds I will post pics tomorrow morning
#3 | |
![]() You need the oil fill tube and not the dip stick tube correct? If you can get me a casting number you want on the manifolds, that would help. I do have several sets of 350 4x4 manifolds here. I will let you kow what I have. I should be able to help you with most of your list Eric. Give me some time and I will post you some photos and prices. Thank you, Thomas |
#4 | |
Thomas sorry for the weak discription. I need the oil fill tube that mounts on the drivers side valve cover. When I get home from work tonight I will pass along what I believe is the correct casting numbers on the manifolds. Thanks again Eric |
Here is what I have.
I have a stock running 307 on a stand. Everything's there from oil pan to valve covers if your interested in any pieces since they bolt up to a 350. The oil fill I have is a long tube with a bracket that bolts onto the intake. I can take pictures tonight.
#8 | |
Thanks Eric |
#9 | |
Hi Eric, Here is what I can do for you. I have some photos but some of the items on your list I have but need to put my hands on them still. I believe you need the casting number 465 on the drivers side exhaust manifold. I have another matched set (in the photos) that are not 465 but a very nice set. It would also depend on if you are setting up to run the factory heat riser on the pass side. The ones in the photo are very nice and sell for $175.00 plus shipping. Valve covers are $45.00 for the pair Timing cover is $20.00 Oil fill tube is $22.50 it will need a little straightening near the mounting hole. Passenger side spark plug shields are $7.50 each. Have them but need to locate. Clutch fan blade with no clutch is $40.00 I have a nice one but not at the shop. I may also have a clutch but cannot guaranty it good $25.00 Let me know what you think and I can get everything in one spot and a shipping quote, if interested. Thank you again, Thomas |
Eric,
Here is a couple pictures of what I have. Sorry they are covered in oil. I will be getting everything cleaned up shortly. As far as prices, make me a fair offer. |
#11 | |
PM Sent
#13 |
Hi Eric,
Here is the other set of manifolds that I have to offer. I sent you a PM also. Thank you again, Thomas |
