01-19-2015, 06:21 PM | #1 |
Where to buy 67-72 5/7 kit.
Pretty much summed up by title. Lookin to drop the 68 down, was gonna use an ece 4/6 but decided to go lower while its apart. Ece doesn't sell 5/7 kits. Where do I find a quality 5/7 for 60-72? Tia
Jack 1968 swb on air |
01-19-2015, 07:14 PM | #2 |
Re: Where to buy 67-72 5/7 kit.
you might try POL but youll need to c notch if going lower than 6 in the rear
1967custom |
01-19-2015, 07:29 PM | #3 |
It'll be a driver so I already planned for a cnotch even with the 4/6. I'll look at pol
01-19-2015, 09:40 PM | #4 |
I did cpp 3" front springs and cpp spindles. In the back I did all ece with 2" blocks. I also got the shock kit for the front from ece. The blocks I did not buy from ece.
01-25-2015, 12:19 AM | #5 |
I pieced mine together. 73-87 junkyard lower control arms ,73-87 Car Quest upper/lower ball joints, inner/outer tie rods and adj sleeves,CTS 2.5"spindles $178 off EBay,CCP 2" front and 5" rear springs, shock relocator brackets $260, McNaughty Track bar $99 all from Summit Racing. All 4 KYB GR2 shocks $62 off Amazon. Using POL brake lines and matching perportioning valve. I'm guessing $800 into the drop and disc brake conversion.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO 71' Cheyenne C10 Hugger Orange on Saddle SWB Besides these two, too Many to count |
