01-19-2015, 06:30 PM | #1 |
Steering column! need help!
Hey guys. I replaced the turn signal switch on my 68 c10 (non tilt) and the bearing/turn signal housing will not go back on correctly. It is rotated probably 2 inches left (counter clockwise). There are 3 tack welds on the column that look like keepers to stop the housing from turning with the steering wheel. It fits on them but once everything is bolted up. It is rotated left and I can twist it left to right with my hand (The housing for turn signal and bearing) where the blinker and hazard switch is. Also my steering wheel rubs. What am I doing wrong? Thanks in advance!
01-20-2015, 12:47 AM | #2 |
Re: Steering column! need help!
No comments??
01-20-2015, 12:51 AM | #3 |
Cant comment, I never had mine off.
Terry Soon to be retired and moving to Bristol, TN. |
01-20-2015, 01:34 AM | #4 |
Post some pics
-Keegan- '72 Jimmy 4x4 - 5.3/4L65E/NP205 swap http://67-72chevytrucks.com/vboard/s...d.php?t=663780 |
01-20-2015, 01:34 AM | #5 |
Ok lol that's better than nothing. I was starting to wonder if my post was visible.
01-20-2015, 09:41 AM | #6 |
How do I post pictures? It asked me to enter a url. What site do yall upload pictures to?
01-20-2015, 09:47 AM | #7 |
Every time I try to upload pictures it says security token missing.
01-20-2015, 10:01 AM | #8 |
There are two or three humps/ slots that the turn housing seats on that. Sounds like from your description what the problem is. I will look for a pic for you.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
01-20-2015, 10:28 AM | #9 |
Look at the 6th pic in this link. Notice three small humps and the larger alignment slot. If you put it together right and get everything seated correctly it will not allow the housing to spin or the rub issue you noted. Hope this helps.
http://67-72chevytrucks.com/vboard/s....php?p=3216427
01-20-2015, 11:20 AM | #10 |
Thanks! I'll take a look at mine. I wish I could post pictures but it won't let me. :/
01-20-2015, 12:31 PM | #11 | |
Hope that helps. |
01-20-2015, 12:44 PM | #12 |
Hopefully these work. |
01-20-2015, 12:46 PM | #13 |
Thanks for the help with uploading the photos guys. Now hopefully yall can help me find the problem.
01-20-2015, 12:48 PM | #14 |
See how it's rotated counter clockwise when it is sitting on the notches? It won't go on straight!
01-20-2015, 01:04 PM | #15 |
01-20-2015, 01:57 PM | #16 |
If I'm looking at it right I don't think the plastic washer with the notch on it is suppose to go in that slot, take it back out and put it in the big slot and it will go down further.
01-20-2015, 11:10 PM | #17 |
Chevy_life, I looked at the picture wrong earlier. If you look at the schematic shown above there should be a bushing seat-metal no.3 and a shift housing bushing plastic no.2 on the bottom side of the shift housing and on the top of shift housing there should be a plastic thrust washer no.40 and a rubber ring no.39 once there in place you can put the turn signal housing on. Hope this helps
01-20-2015, 11:44 PM | #18 |
Thanks!
