Frame question
I have a 1960 c-10 2wd short bed the person I got the truck from hacked up the front of the frame to put a custom bumper on and didn't know what they where doing I'm trying to figure out what year frames I can us I found a 72 k5 4x4 blazer frame and trying to figure out if I can us it or not
Re: Frame question
Give Tom a call at Tuckers 702-258-1955 he just picked up a couple more trucks and might have what you need. I just got high hump floor from him.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
Never Ending Projects
Re: Frame question
'60-'62 frames are very different than '63-'72 frames. They are narrower in the front and the frame rails are different in the rear. Not sure if any of the body mounts would match up with the frame and cab/bed. I am sure someone will know the real answer but do all your research before pulling the trigger on a later frame, hence you don't end up with a ton more work.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
![]() Join Date: Sep 2007
Re: Frame question
yeah theyre way different, torsion bar suspension and narrower. you might want to see about just getting frame horns from a doner truck and welding on to your existing frame
1967custom |
Re: Frame question
Thank you for the feedback it was a lot of help Def going to due some more research before doing anything
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: Frame question
The easiest would be to just replace a section of the front of both frame rails. A swap to a '63-'66 frame is doable but it is quite a bit of work changing a complete frame. The '63-'66 frame would be the best frame to use if that is the route you want to go. Just be sure you first contact your local DMV and find out what it takes to make a frame swap legal in your county/state.
