Will 2nd gen bbc Camaro headers fit? 60-66
I could of swore I had previously found someone who had used 2nd gen camaro headers with a 454 but now that I'm about to go buy a set I can't find the info again. Any opinions?
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: Will 2nd gen bbc Camaro headers fit? 60-66
I'm not sure about BBC Camaro headers, but Chevelle headers will work as long as you aren't keeping the bellhousing crossmember. The Camaro headers shouldn't be much different than Chevelle headers. I believe you also have to be careful not to move the engine too far forward. You might search in the Racing and High Performance section.
![]() Join Date: Apr 2009
I used Nova Headers Once nice and Tight
1966 GMC K25 V6 351E Original Utility Truck 2000 C3500 Hot Rod Utility Truck 2003 ROAD KING 100th 124ci 6 Speed 145CI M/P Pro Street FXR 2002 FXDP 2007 2500HD DURAMAX. DD Studio Teamsters / Mechanic Retired GM Master Tech 20 Years Retired Ford Tech 15 Years |
Thanks captain and shorty. So as it turns out the kid really had Chevelle headers that he bought for a camaro. So I now have Chevelle headers with 2in primary's that look like they are going to work after I trim and modify the trans support.
