Old 01-20-2015, 05:06 PM   #1
gasmn1620
gasman's 87 r10 build
as it sits now
first box of parts showed up. Moog ball joints, tie rod ends, pitman and Iidler arms, etc. It's starting now so I'll be updating this constantly.
gasmn1620 is offline   Reply With Quote
Old 01-20-2015, 05:24 PM   #2
gasmn1620
Re: gasman's 87 r10 build
put in some new updated head lights and my headlight buckets were rusted to poop. I found some in the junkyard that just hard surface rust so I got them, sand blasted them, and painted them gloss black. Didn't get a shot of them painted but here is the blasting before and after.
scored a mint drivers side vent window when I was out pulling the headlight buckets too.
and I got some custom center cap stickers for my wheels. They are aluminum and are pretty ridgid. Really nice for $20.
Old 01-20-2015, 07:45 PM   #3
gasmn1620
forgot to show the new lights installed
Old 01-20-2015, 07:52 PM   #4
Shifty One
Shifty One's Avatar
Looks good!
Old 01-21-2015, 10:25 PM   #5
gasmn1620
3 more boxes came today.... spindles, u-bolts, rotors, pads, wheel bearings.... springs will be here tomorrow.
Old 01-22-2015, 03:02 PM   #6
gasmn1620
reshly blasted a-arms
Old 01-22-2015, 05:35 PM   #7
83swb
Sure wish I had the chance to start with a nice clean southern truck like that. Looks like the beginning of a badass looking truck, can't wait to see it a little lower. Keeping the wheels or going with something different?
83swb is offline   Reply With Quote
Old 01-23-2015, 12:28 PM   #8
gasmn1620
a-arms blasted clean for paint. They are ccurrently at the machine shop getting ball joints pressed in. I'll be hanging on to these wheels for now. Depending on how low it sits and when I bag it I may change them and get some 20s with better offsets.
Old 01-23-2015, 11:22 PM   #9
gasmn1620
installed a a arm bushings today. Scored the bushing holder with a sawzall then used a punch to bend them and then knocked them out.
Old 01-23-2015, 11:23 PM   #10
gasmn1620
Old 01-23-2015, 11:23 PM   #11
gasmn1620
Old 01-24-2015, 03:34 PM   #12
gasmn1620
I've hit a road block. I ordered the DJM spindles that matched my rotor size and the inner bearings are too small for the axle.
here's the spindles
http://www.summitracing.com/parts/dj...-size/5-7l-350
here's the bearings
http://www.summitracing.com/parts/tmk-set6
and here are my rotors
http://www.summitracing.com/parts/su...-size/5-7l-350
for some reason I think I ordered rear rotors when my truck has drums. dammit
Old 01-24-2015, 04:58 PM   #13
gasmn1620
Now I'm all effed up. Apparently summit directed me to the wrong spindles so I have nothing that matches up.
Old 01-24-2015, 05:27 PM   #14
gasmn1620
<a href="http://s48.photobucket.com/user/byggbamaboy1626/media/Mobile%20Uploads/20150124_152510_zpsy1zfw5qd.jpg.html" target="_blank"><img src="http://i48.photobucket.com/albums/f244/byggbamaboy1626/Mobile%20Uploads/20150124_152510_zpsy1zfw5qd.jpg" border="0" alt=" photo 20150124_152510_zpsy1zfw5qd.jpg"/></a>ny idea why the new spindle are putting the rotors out to far?
Old 01-24-2015, 05:28 PM   #15
gasmn1620
ny idea why the new spindles won't let the rotors sit correctly?
Old 01-24-2015, 08:02 PM   #16
gasmn1620
the djm spindles were 1/4 inch thinner at the tab that floats over the rotor where the caliper bolts on. This part number says it's for the 1.25 rotor trucks but it needs a SET5 bearing. Summit/autozone/orielly all return a part # SET6 for my inner bearing but they don't work. The stock rotors I bought at autozone took a SET5 bearing too. so pissed.
Old 01-24-2015, 08:32 PM   #17
83swb
Ok so do the auto zone rotors and summit rotors both fit SET5 bearings? If so than the spindles are obviously wrong. I have the light duty brakes on my truck and my spindles look much more like the djm's than your stock spindles do, SO summit probably mislabeled the spindles as a 1.25" heavy duty brake model instead of light duty.
Old 01-24-2015, 09:20 PM   #18
gasmn1620
that's what I'm thinking. I got mislabeled spindle... and that's effing up my whole day
Old 01-25-2015, 12:41 PM   #19
gasmn1620
got partially done. Front is just springs with my original spindles, back is the bracket from specialtyretail here. Doesn't sit to bad but I want the front lower for sure.
Old 01-25-2015, 11:37 PM   #20
50seven
50seven's Avatar
The summit part number overview states you have 1" rotors and the DJM drop spindles are 1.25". looks to me like you have the wrong rotors........? Get the 1.25" rotors would be my choice
50seven is offline   Reply With Quote
Old 01-25-2015, 11:48 PM   #21
50seven
50seven's Avatar
Brand:
Summit Racing
Manufacturer's Part Number:
SUM-BR-62012L
Part Type:
Brake Rotors
Product Line:
Summit Racing® Extreme Performance Cross-Drilled Brake Rotors
Summit Racing Part Number:
SUM-BR-62012L
Intended for Street Use:
Yes
For Use with Stock Calipers:
Yes
Rotor Construction:
Vented
Rotor Style:
Cross-drilled and slotted surface
Rotor Outside Diameter (in):
11.860 in.
Rotor Thickness (in):
1.035 in.
Rotor Material:
Iron
Rotor Finish:
Natural
Quantity:
Sold individually.
Notes:
Fits applications with 11.860 in. rotors. Will not work with models with 11.016 in. brake rotors.
In-Store Pickup:
Choose In-store pick-up (OH, GA, NV) on our web site.
Old 01-26-2015, 12:59 AM   #22
gasmn1620
Got 1.25 rotors and the bearings that fit them and they still wouldn't go on the spindles.
Old 02-11-2015, 12:54 PM   #23
gasmn1620
I'm horrible at taking pictures and keeping up with this. I have 3" spindles and 3" springs in, the front end is completely rebuilts, fender wells are pulled, fenders rolled, but now I gotta do something about the fender wells and inner fender area that is too close to my wheels. Wish these things had a little higher offset. I think they are +19..... a +30 or 40 would be beneficial right now.
before
after
Old 02-11-2015, 12:56 PM   #24
gasmn1620
i know... the pics aren't good. I'll get some nice ones soon. It's almost spring here in the panhandle and the beach would be a sweet backdrop.
Old 02-11-2015, 12:59 PM   #25
gasmn1620
next is exhaust, because my factory pipes are really close to the ground now. Gonna do a simple true dual from the manifolds back.
