Not too old to learn
390hp 350 crate using oil
This is a general inquiry about a new engine using oil.
I bought the new crate engine from a GM dealer several years ago and stored it pending rebuilding my 68 C10. A year ago finally got it ( the truck) put back together and installed the 350 with a Holley and an Edlbrook intake stock dual pipe exhaust and fired by MDS electrics. Did the breakin at 2000 rpm for 1/2 hour drained out the Lucus breakin oil filled up with regular Valvoline 10-30 and hit the road. Runs great nice smooth power through out easy rpm watching oil pressure and temps. After about 100 miles stated driving at higher speeds, checked the oil level uhmmm down 1/2 quart so now that seems to be it's thing, 100 miles add 1/2 qt Plugs are clean, but noticed blue smoke at restarts while engine is warm. My first suspect is Valves ???? As of today I only have run it about 1800 miles. I have read several other forums and comments that GM valve stem seals are a problem. Any body else experienced this with new crates ?????
1968 C10 a way to long restoration. |
![]() Join Date: Dec 2012
Re: 390hp 350 crate using oil
Valve stem seals dried out from sitting?.....
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
#3 | |
If that's a 350-290HP these are valve-seals listed on this link from GM. Not sure how old the crate engine is if the parts match. 10212810 8 Seal, Int Vlv Stem Oil 12564852 8 Seal, Exh Vlv Stem Oil http://www.chevrolet.com/content/dam...e-12499529.pdf You might try some "high miler" oil, it has seal softener in it. I put in in my 350-330HP and it stopped the oil cooler hose leak. Last edited by mechanicalman; 01-20-2015 at 10:49 PM. Reason: add-on |
It is the 290hp 350 I typed it incorrectly on original posting.
I'm going to talk with GM folks and see if there is a record of failed seals. I can't believe the seal would be dried on a brand new engine.
#5 | |
If it's only on start-up that would, IMO, eliminate intake gasket leak (oil sucking into the ports). Another thing to consider, there was another 290HP SB crate engine before the most recent one, it had centerbolt valve covers. It was a 1 pc seal, a much better engine than the recent one. Which one do you have? The older version of the 290HP was identical to the 300HP. It had a dish piston shortblock with small chamber Z28/formula 350 style heads, flat tappet cam similar to the later 290 but less intake duration and 112 lobe centers. |
#6 | |
about 5 years still plastic wrapped in factory shipping cradle. I only pulled a few random plugs which are clean ,no oil build up, but I will pull all there may be one or two seals out or pintched. I think the intake manifold might be worth redoing as there is a very light blue exhaust mist at idle.
Check to see if your pcv is working correctly also...
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
#8 | |
I put factory GM gaskets on it and the problem was 100% solved. |
#9 | |
changes . When I pull the manifold off, I'll look closely for any leak area. Thanks for the tip.
