Old 01-20-2015, 09:32 PM   #1
64jmb
64jmb's Avatar
1962 C10 Custom Cab Question
Hello,
I have a few questions about the custom cab interior and the engine for a 1962 C10 pickup. I wanted to know if anyone knew where I can find original material for the 62 custom cab interior with the decorative insert, not for the 1961 or 1963 C10's as they are different. Here is a 1962 picture I found and it is the same material I would need, and also I believe this truck came with a 327. At least it has one in it now I think based on the air cleaner on it and the orange visible paint on the intake. It has been basically owned by the same family since 1962, and I saw on the 62 chevy truck brochure it was available for the bigger truck. Could that be custom ordered for the C10? Let me know. thanks
64jmb is offline   Reply With Quote
Old 01-20-2015, 10:06 PM   #2
dtkarst
Re: 1962 C10 Custom Cab Question
As far as I knew, the 66 models were the only ones to come out with a factory 327. I could be wrong though..
dtkarst is offline   Reply With Quote
Old 01-20-2015, 10:42 PM   #3
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
I found my original 63 stuff at originalauto.com. Give them a shout. You just never know.
Old 01-21-2015, 12:16 AM   #4
LVPhotos
LVPhotos's Avatar
Mine was 283, 327 didn't come out til 1966 according to book. The engine would be green/grey?. Not orange. Would have genarator not alternator.
http://67-72chevytrucks.com/vboard/s...=588074&page=2
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 01-21-2015, 12:19 AM   #5
LVPhotos
LVPhotos's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=439322
Old 01-21-2015, 12:49 AM   #6
64jmb
64jmb's Avatar
The motor I think is grey and the intake is orange to much dirt on it to see it I need to clean it off first to see but the air cleaner looks like the one in the 62 brochure for the big trucks 327.
Old 01-21-2015, 12:50 AM   #7
64jmb
64jmb's Avatar
Could you special order a 327 for the C10 in 1962?
Old 01-21-2015, 12:51 AM   #8
64jmb
64jmb's Avatar
Ill check this out I looked about a year ago but was unable to locate the correct pattern. Thanks for letting me know.
Old 01-21-2015, 01:27 AM   #9
64jmb
64jmb's Avatar
I just found this picture on a older post from oem4me. This is the seat material and seat I need.
Old 01-21-2015, 01:31 AM   #10
64jmb
64jmb's Avatar
It does have a generator, and I think the motor is grey and the intake is orange. Too much dirt to tell yet for sure. The air cleaner looks like the 1962 medium duty truck 327 picture. Could this be special ordered for the C10?
Old 01-21-2015, 01:48 AM   #11
Captainfab
60-66 Nut
I don't know if a '62 could have been ordered from the factory with a 327, but it certainly could have been dealer installed for the customer.
Old 01-21-2015, 02:15 AM   #12
Vincenthdfan
My very original, unmolested 62 has a 283 in it with an original generator on it as well.
Vincenthdfan is offline   Reply With Quote
Old 01-21-2015, 02:18 AM   #13
Vincenthdfan
My original interior on my 62...well except for the 57 Chevy BelAir clock someone put on the glovebox door back in the day, lol.
Old 01-21-2015, 12:51 PM   #14
LVPhotos
LVPhotos's Avatar
Here's one from BJ Auction
Old 01-21-2015, 02:58 PM   #15
64jmb
64jmb's Avatar
Very nice truck I believe I saw this truck last year at Barrett Jackson.
Old 01-21-2015, 03:00 PM   #16
64jmb
64jmb's Avatar
That seat is the same seat I have. I think I may have found some material for the seat through original auto possibly.
Old 01-21-2015, 03:07 PM   #17
64jmb
64jmb's Avatar
Here is a picture of the engine compartment as left original. Look t the air cleaner, it looks like the C50/60 one or for a 57 chevy 327. Is this stock? It looks correct to me like a factory 327.
Old 01-21-2015, 03:23 PM   #18
64jmb
64jmb's Avatar
I posted a picture of the 62 C10 engine compartment, let me know what your thoughts are. thanks
Old 01-21-2015, 03:29 PM   #19
64jmb
64jmb's Avatar
Also I am going to need a new center for the horn ring are it is a white deluxe steering wheel.
Old 01-21-2015, 07:38 PM   #20
dtkarst
My guess is its not a 327, I havent seen an original air cleaner like that on a C10 before. And as far as I know you couldnt get a 327 in any half ton until 66
Old 01-21-2015, 08:39 PM   #21
60-66
60-66's Avatar
According to the 1962 Chevrolet truck Data Book the 283 was the only V8 available in 10 20 and 30 series, In fact it does not show the 327 until you get to the C60 series trucks. All you need to do to verify is clean the pad on the front of the engine in front of the passenger side cylinder head. There will be some stamped letters and numbers. If you can post those I can identify your engine for you. That air cleaner would not be correct either for a 10 series. Your engine should be grey also.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 01-21-2015, 08:45 PM   #22
64jmb
64jmb's Avatar
Thanks for the info.
Is that the correct air cleaner that is in the picture for a 283? I believe the motor is grey and the intake may be orange.
Old 01-21-2015, 08:58 PM   #23
60-66
60-66's Avatar
Yes, the round oil bath on the left is correct for 62 283. Your engine would have been a 2 barrel though.
