center support bearing and driveshaft R and R
My truck is a 67 GMC 1/2t shortbed with leaf springs (if that makes a difference). The driveshaft should be all stock. All I can remember doing in the 30+ years I've had this truck is changing the u-joints in the 1980's. However, I did blow out a couple rear ends in high school that my dad had replaced at a local junkyard. I'm assuming they just installed a used rearend without replacing the driveshaft.
I'm going to pull the driveshaft and center support bearing to replace bearing and u joints and have the driveshaft balanced at a local driveshaft shop. I assume I just unbolt the center bearing hanger and bring the whole thing to the shop. Is this all there is to it? Is the center support bearing a specialty item, or will the shop be able to easily order a new one? I've read about problems with an aluminum bracket and some sort of welding repairs. Is this something I need to be be aware of? I'm planning on installing a crate 350 in the truck, so won't be turning any huge hp. I'll be using my stock 4 speed granny trans for the next few years, until I figure what 5 speed I want to install. Lastly, my truck will be lowered about 6" total in the rear, by removing leafs and adding a droplink. Will this require a shorter driveshaft or extra slipjoint? Here are some pics of my center support bearing and housing. Thanks!
1967 GMC 1500 SWB. Driving this truck since I was 14. |
Re: center support bearing and driveshaft R and R
You have the more uncommon carrier bearing, but with the part # a shop should be able to get it for you no problem. O'reilly does not show this one for my truck in their system and I didn't check other years. Here ya' go:
http://67-72chevytrucks.com/vboard/s...d.php?t=656307
the boat guy
You have the "good" carrier bearing. You will be fine taking it to a shop to have the carrier replaced and the shaft ballanced.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
Thanks for the info and the link. I'll pull out the whole assembly and drop it off at the driveshaft shop. If they have a problem finding the part I'll give them Mike's Neapco part # N212050x.
I have the same carrier on my 69, my local NAPA store had one in stock. You might get lucky!
http://smg.photobucket.com/albums/v655/aaronhero/ |
