Two questions on auxiliary gas tank
While removing the bed, a paint/body guy poked a hole in the aux tank mounted just behind cab, in front of rear wheel. While the bed was off he brazed the hole, but it still weeps enough to be a problem.
1. This tank is wider at the top to fit the side panel contour and am wondering if there is enough clearance between the body and frame to drop it out - without removing the bed. Anyone know how these "not-square" aux tanks were installed? Maybe remove the rear wheel and it would slip out toward the back? 2. Is there a GOOD (meaning "really works well") product that would seal a small weep leak when applied to the outside of a gas tank? Thanks for any info/advice.
CCCC 67 Sting Ray Coupe 327 4sp; 68 K10 Suburban 327 4sp; 69 K20 Lifted 383 4sp; 69 C80 Fire Truck 478 V6 5sp/2sp; 69 C20 Longhorn 327 4sp; 70 C30 Wrecker 350 4sp; 70 C30 Flat Bed 350 4sp; 71 C20 LWB 350 4sp; 72 K5 Blazer 350 4sp; 72 C30 Flat Bed Gooseneck Hauler with sleeper 350/TH400; 72 C20 Longhorn 402 4sp; 52 Mack LTL Supercharged Cummins 5sp x 3sp; 01 Dodge 5.9 HO Cummins 6spd; 02 Safari Trek 2430 8.1 Vortec on Workhorse Chassis; 03 Silverado 2500 HD 4wd Duramax/Allison Moved but still in the family 70 C20 Custom Camper 350/TH350; 72 K5 Blazer CST Highlander 350/TH350 Recently sent to new homes 72 C30 MoHome 402 4sp; 72 K5 Blazer Conv 350 4sp; 75 GMC 6000 Aerial 350 w Allison; 72 GMC 3500 Utility 350 4sp; 70 GMC 3500, 350 4sp |
#2 | |
![]() Join Date: Dec 2010
Re: Two questions on auxiliary gas tank
Here is a picture of the seal all. It can be found almost anywhere!
Carpe manana
![]() ![]() Join Date: Dec 2010
OEM aux tank? I've dropped aftermarket "Travel Tanks" without removing the bed and these are more-or-less the same shape as the OEM 71-72 aux tank.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
gipper - thanks very much for that. I will get some "Seal All" at the first opportunity.
DeadheadNM, thanks. Don't yet know if it is an OEM tank - but am going to try to find out. This tank has rounded/contoured edges and does widen as it rises - and longitudinally is narrower at the back end to fit around the spring aspects. I sure hope it will drop down/out. Any other thoughts out there?
#6 | |
The one I had was leaking about 20 years ago. The shop I took it to said that because it is made of plate steel and not sheet metal like OEM tanks, it was very repairable. I've used it ever since then with no further issues.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
Carpe manana
The OEM tank is more or less shaped like this Travel Tank here: http://67-72chevytrucks.com/vboard/s...91&postcount=4
Remainder of the linked thread also shows a differing aftermarket style: http://67-72chevytrucks.com/vboard/s...d.php?t=452485 Does the shape of your tank resemble either?
Thanks mrein3 and DeadheadNM - appreciate the help.
DeadheadNM, thanks for the photos - mine does not look like the steel plate tanks with flat panels. It is sheet metal with rounded edges and a seam - and definitely widens as it rises. It is hung on two steel straps with long bolts dropping from the bed. The truck build sheet lists the "fuel tank system" as A-H-O. Anyone know about that? Am thinking that this must be an aftermarket tank. Am looking for the fuel tank sealer picture by gipper - anyone have any success with another type/brand? Thanks again for the help.
Carpe manana
How far from ABQ are you? I have a pair of plate steel dealer installed travel tanks sitting at my house in ABQ that I'll likely never use let alone up here in MT. You could ditch your existing tank.
Hi DeadheadNM, and thanks. I'm about 200 miles SW, but I do have to come up to Alb occasionally. Let me look this over. Will contact you here if that looks like a good move. Thanks very much.
Carpe manana
You bet - shoot me a PM if you want to go that route. Pete
