Old 01-21-2015, 07:49 AM   #1
yoshi
yoshi's Avatar
Vacuum
On an SBC 350 what creates the vacuum at the carburettor? Thanks
yoshi's 49 project
yoshi is offline   Reply With Quote
Old 01-21-2015, 09:04 AM   #2
MikeB
MikeB's Avatar
Re: Vacuum
Most carbs have 3 sources of vacuum -- a large port for the power brake booster, and two smaller ports.
The large port and the small port (closest to the carb base) are manifold vacuum.
The small port that's a little higher up on the carb is known as "ported" vacuum. There is little to no vacuum at this port until the throttle blades begin to open.
The small ports are used for distributor vacuum advance, transmission modulator, and emission controls, depending on the vehicle.
There is some debate on which small port to use for vacuum advance. Personally I've had success using both, depending on engine idle vacuum (mostly a function of camshaft duration and overlap).
Mike
1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress.
1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 01-21-2015, 09:07 AM   #3
yoshi
yoshi's Avatar
Re: Vacuum
But where or how is the vacuum created?
yoshi's 49 project
Old 01-21-2015, 10:06 AM   #4
68post
Re: Vacuum
Pistons moving down in their bore with the intake valve open. This lets air rush down thru the carb from above and thru the intake and into the cyl. head past the valve and into the cylinder.
14.7 psi of atmospheric pressure above the carb and zero psi in the cylinder because the piston is moving down and creates space for the air to rush in. Air flows thru to fill that space !
68post is offline   Reply With Quote
Old 01-21-2015, 10:44 AM   #5
yoshi
yoshi's Avatar
Re: Vacuum
Ah right thanks, low vacuum would be because if a leak or worn rings then
yoshi's 49 project
Old 01-21-2015, 10:49 AM   #6
86c20
86c20's Avatar
Re: Vacuum
just remember if the blads on the carb are closed you have high vacuum open no vaccum.
just like was said the piston needs to make a low pressure area and then the carb blads need to make a restriction, that gives you vacuum. this is also why diesel's dont have vacuum as they have no restriction on the intake system
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph
1985 k30 "the ice cream truck from hell" no rust az truck
197-8??? c30 "ramp truck" 454
1978 monte carlo 350 350th with 2.73 gears. no rust. sc car
86c20 is offline   Reply With Quote
