60-62 dual exhaust pic
Off my 1962 short box. Drops in front of rear axle. See my build page 3 for on truck pic. Shorties or rams. For those looking for routing. 1" bar across x to hold muffler rubber hangers. The other mounts are at center x frame.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
![]() ![]() Join Date: Aug 2013
Re: 60-62 dual exhaust pic
What headers are you running? Was told 2466 HKR Hooker Compatition was what works with Porterbuilt clip.
Those are 1970 CHEVROLET EL CAMINO Hedman Elite Heavy-Duty Headers 68608
Summit's PN HED-68608. My front suspension is stock except for the drop spindle/disc set up. |
It looks like your application for headers is the same as mine....It seems this style is most popular in the GM Chevelle/Nova's
My motor was up against firewall on stock v8 spot now forward with new Porterbuilt crossmember. More room. It's the hydraulic cluch that got in the way.
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
Is there a kit, or did you guys have yours done at a muffler shop?
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
Or, perhaps some pieces are available pre-bent?
"Where were you in '62?"
![]() Join Date: Jul 2004
Mine is here:
http://67-72chevytrucks.com/vboard/s...d.php?t=345206 And here: http://67-72chevytrucks.com/vboard/s....php?p=6431013
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN ![]() ![]() ![]() ![]() ![]() ![]() ![]() "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
I just saw this thread and realized you were asking for some info on parts used to make my exhaust....I started with the two kits below and also used two stainless flexible joints I scored on eBay for cheap. That's about it for my system other than some stainless tips I had. Since I used a Torsion front I chose the "x" pipe to travel between the two torsion keys. I did it myself using most of the pipes in both kits. Also I had used the "imco" mufflers from Summit...
Joe Part Type:Exhaust Pipes, Multiple Bend Kits Product Line:Flowmaster S-Bend Combo Packs Summit Racing Part Number:FLO-15926 Brand:Summit Racing Manufacturer's Part Number: SUM-642125 Part Type:Exhaust Crossover Pipes Product Line:Summit Racing® Universal X-Pipe Kits Summit Racing Part Number:SUM-642125 |
#13 |
Perfect.
Having a 62 X-Frame under my 65, I was hoping I could find a kit that would work with the X-Frame. I'm also keeping the torsion bar suspension.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 02-01-2016 at 12:53 AM. |
#14 |
![]() Join Date: Dec 2014
Thanks for posting up this info, I was just looking for routing for the x frames not too long ago
#15 |
You have to get creative when using a torsion bar set up....its just in the way to be easy. That x pipe is the lowest point of my whole truck so the skid plate protects both the exhaust and keys....
