boxed frame
just wandering if anyone has boxed there frame. I love the look, but it looks like a lot of work.
Re: boxed frame
It is a ton of work and why would you need to? Unless you have 1,000 hp or so you won't need a boxed frame for the rigidity of the frame to help the suspension work. Sure newer trucks are boxed and the newest still are boxed all the way almost to the rear bumper brackets but they were designed that way and they had crash worthiness in mind when on the drawing table. Also hydroformed frame rails are made to have crash zones or they are better known as crumple zones. The main purpose for them is to bend a certain way in a certain impact to keep the frame and drive train out of the passenger compartment. That is not gonna happen with a boxing of a regular frame your not gonna have that control. That could lead to a very unwanted ending in some circumstances. All of that to say this you really don't need it they built trucks for many years without boxed rails and those trucks a lot of them are still working and riding now. Jim
Re: boxed frame
Re: boxed frame
I can see no reason to do. These trucks were very well designed from factory. I know boxed frames have a tendency to rot out and you only see it when you're laying under your truck
#5 | |
Re: boxed frame
Re: boxed frame
I know an old rancher up the road that drives a '72 K20 that he broke the frame on a couple of times.
#7 | |
Vintage 4x4s
Re: boxed frame
I have noticed some 67 to 72's where the bed has "kissed" the back of the cab. Under high loads/bumps the bolts that hold the bedsides to the header panel can contact the back of the cab. The frame flexes a tad too much, even though it doesn't yield (stay bent).
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ![]() 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
![]() Join Date: May 2003
Re: boxed frame
I split the frame on my 1st 72 swb 4x4 a few times. But I use & abused the truck for years before that happened. I plowed with it every winter, hauled firewood, use it like a skidder, loaded it up with stone until the front end was hardly on the ground, and yes dented the corners of my cab from the bed hitting it. Eventually had to swap frames, but I would never box a frame, too much work to do it right. But that's me, many have been done. The truck I'm building now will live a pampered life, it will never be driven in the snow, and probably won't hall anything heavier than a bag of trash to the dump....
That’s a ton of work to do just for the looks !
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
Re: boxed frame
I boxed a 72 that I had in high school. I had the cab and bed off so I thought why not. while I was boxing it I also ran 1" conduit inside the frame too for the wiring. I was working part time for a street rod shop then and it was pretty common to run conduit for the wiring and even the brake lines inside the frame before boxing them
1967 C10 lwb two tone, 305 & rat fink style floor shifted 700r4, 20" steelies 2004 2500HD utility bed aka Brutus |
