01-21-2015, 07:39 PM | #1 |
Cancer
Hi I found me this 1963 Chevy pick up C 10 it's got a few Russ spots referred to the picture I was looking for this truck for several years it's the only one I could find it is the year I was born so it's pretty special to me now do they sell patch panels to repair this or should I toss it
01-21-2015, 07:50 PM | #2 |
Re: Cancer
Yes they do, Google bills truck parts and search under new parts
01-21-2015, 08:26 PM | #3 |
Re: Cancer
Thanks bud
01-21-2015, 08:29 PM | #4 |
Re: Cancer
Here she is fellas
01-21-2015, 08:31 PM | #5 |
Re: Cancer
I'm not sure about fender skirts?hmmm
01-21-2015, 10:07 PM | #6 |
Re: Cancer
Nice looking truck except that it looks like a dog with its tail between its legs.
01-22-2015, 12:45 AM | #7 |
Re: Cancer
01-22-2015, 02:07 AM | #8 |
Re: Cancer
1966 GMC K25 V6 351E Original Utility Truck 2000 C3500 Hot Rod Utility Truck 2003 ROAD KING 100th 124ci 6 Speed 145CI M/P Pro Street FXR 2002 FXDP 2007 2500HD DURAMAX. DD Studio Teamsters / Mechanic Retired GM Master Tech 20 Years Retired Ford Tech 15 Years |
01-22-2015, 02:39 AM | #9 |
Re: Cancer
01-22-2015, 10:53 AM | #10 | |
1961 crewcab
Re: Cancer
I have not tried to use that patch panel. but the several 60-63, and 64-66 roofs that I have cut up were the same upon visual inspection. as far as I can tell the front panel, roof skin, and headliner panel all interchange, it is just the posts and their inner support pieces that are different. I am curious as to why that patch panel is listed 64-66 only, I wish they included a reason, because from what I can tell they should all be the same...
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
01-22-2015, 03:47 PM | #11 |
Re: Cancer
thanks for the input fellas,i just realized the firs pic shows blurr,i will try and post better pics.im with you on that jonzcustomshop.thx
01-22-2015, 03:58 PM | #12 |
Re: Cancer
Hope it's a better pic
01-22-2015, 06:06 PM | #13 |
Re: Cancer
Here we go again
01-22-2015, 06:08 PM | #14 |
Re: Cancer
upside down
01-22-2015, 06:52 PM | #15 |
Re: Cancer
nice truck ! keep us posted on the repairs
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
01-22-2015, 07:19 PM | #16 | |
Re: Cancer
Hope that helps.
Jeremy |
01-22-2015, 07:56 PM | #17 |
Re: Cancer
will do sleepysal,thank you jeremy thats a big help.
01-22-2015, 09:57 PM | #18 | |
1961 crewcab
Re: Cancer
as you fix this inner piece, you will probably find that the outer piece, while it looks good on the outside, is probably shot as well, so you might need both the inner and outer patch panels,,, another thought is to source rust free roof, and just replace the whole thing... I had a truck with rust in that same spot, -I think the common culprit in these trucks in this area is a mouse nest- after I got the roof skin off, all three pieces turned out to be rusted through, inner outer , and roof skin! if you do not replace the whole roof I suggest removing the roof skin, so you can get good access to the repair. these shots are off the roof I didn't use on the truck I chopped.
01-23-2015, 12:25 AM | #19 |
Re: Cancer
Lots of good info jonzcustomshop thx
01-23-2015, 10:16 AM | #20 |
Re: Cancer
Hey guys. That upper windshield to roof repair piece Jeremy shows. Is that a common part available for 64-66? I've only seen it listed for 60-63.
Robert 1965 Chevy C10 http://67-72chevytrucks.com/vboard/s...d.php?t=374373 1997 Chevy K2500 6.5 diesel |
01-23-2015, 11:09 AM | #21 |
Re: Cancer
The piece I pictured is the inner roof. Listed for 64-66. The outer piece is usually listed as 60-63 but it fits on my 65.
Jeremy |
01-23-2015, 11:33 AM | #22 |
Re: Cancer
Thanks Jeremy. Can you give me a part number and where you got it?
