Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 01-21-2015, 10:38 PM   #1
Deerelindel
1978 C50k rear end change
I am currently building a 1978 C50 pickup truck. The truck has the 10 lug pattern, my question is i want to put a 2 spd rear in it, can i take a rear end with the dayton spoke pattern and put the 10 lug pattern on it?
Deerelindel is offline   Reply With Quote
Old 01-22-2015, 01:23 AM   #2
Bobb
Re: 1978 C50k rear end change
Hy Deerelindel, you will have to swap the hubs and brake drums if the bearings are the same. If both differentials are the same make you may be able to just swap center sections in the housing, hope this helps.
Bobb is offline   Reply With Quote
Old 01-22-2015, 08:28 AM   #3
Deerelindel
Yes that does help. Thanks
1968 GMC 1 ton 4*4 with Detroit Diesel 6v53t 9ft stepside
1978 Chevrolet C50 350sb 8ft fleetside
Old 01-23-2015, 04:13 PM   #4
MattBMiller
MattBMiller's Avatar
What are you doing with the rear axle you have in the truck now? what ratio?
MattBMiller is offline   Reply With Quote
