01-22-2015, 04:15 PM | #1 |
for those of us wanting a OEM radio
Heres some inspiration. Original 67. I polished up the original paint, cleaned the heck out of everyrhing, found and used the oem brackets and used 2 4x6 speakers and wired for an 8ohm load. I even used the braket to hold em in. Tricky work. And did you guys know that the cabs without factory installed radios have two dimples where the bracket bolts up? Very helpful
1967custom |
01-22-2015, 04:16 PM | #2 |
Re: for those of us wanting a OEM radio
Sorry about the pics being sideways. You can see in the paint where the delte plate for all those years
1967custom |
01-22-2015, 04:36 PM | #3 |
There's nothing wrong with an AM radio if your area has the channels. Nice work cleaning it up! I was sort of doing this though..... haha
01-22-2015, 06:39 PM | #4 |
ha!! i know i didnt hold the camera phone correctly! if mods want to flip em id appreciate it.
right now it looks like i went old corvette style
1967custom |
01-22-2015, 07:05 PM | #5 |
Cruzin
Best look in my opinion, I love the simple look.
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
01-22-2015, 07:08 PM | #6 |
yeah me too. why cut the dash right?
1967custom |
01-22-2015, 08:18 PM | #7 |
RAT1968 '68 Cab/'71 Parts
flip.
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
01-22-2015, 09:43 PM | #8 |
Ahhh much better. Now it doesnt look like my cab flipped off the frame! Thank you
1967custom |
01-22-2015, 10:08 PM | #9 |
You can send your origional radio out for a internal conversion that includes FM, RCA's ect.
Heres a thread on it. http://67-72chevytrucks.com/vboard/s...d.php?t=657008
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
01-22-2015, 11:32 PM | #10 |
All i really want on it is a cleaner am fm receptor i gues and definatly a blutooth but thats gonna be after i get this troka back together and roadworthy
1967custom |
01-23-2015, 12:09 AM | #11 |
I guess mine came with the radio.
1970 C20 350/TH350, LB God Bless our Troops |
01-24-2015, 10:42 PM | #12 |
I'm hoping to refurb or replace the factory radio with one that has the old school look but has the hidden bells and whistles.
What's involved in removing the radio on these things? (Truck is in another town, else I'd go out and stick my head under the dash.) thanks
Brian '69 GMC C15 Inline 6, 230ci (possibly 250ci) |
01-25-2015, 09:17 AM | #13 | |
Support brace and wires in back. Pull off knobs, 2 nuts hold stems to the dash. Pull back and down. Someone should correct me if Im wrong. HTH..good luck...don t. .... |
01-25-2015, 11:33 AM | #14 |
The heater controls are in the way also, for removal. I have a parts cab that was painted at the factory with delete plate in place, raw dash underneath!! That would be a rude awakening if you choose to upgrade to a radio in your new truck.
01-25-2015, 12:18 PM | #15 | |
I've been joking that I'm going to put a new radio/speaker in the truck, so at least I can listen to music while I try to get it up and running. LOL
01-25-2015, 12:49 PM | #16 |
My truck came radio delete but was painted from the factory underneath the plate. I removed glove box to access easier. My radio delete plate is mounted on the floor heat duct just to keep it in truck for conversation piece. I also added a bracket to the dash using the bottom heater control screws which needs to be painted yet so I can clip my phone with otter box on it and can still use heat controls.oem radio works with single dash speaker but I mounted an amp and two speakers under the seat and hid wire under floor mat up and behind dash
and through ash tray to plug into earphone jack on my phone. This way kind of looks stock but can still enjoy music or podcast from my phone. Sorry about upside down picture but could not seem to correct it. |
01-25-2015, 12:53 PM | #17 |
I haven't priced any yet, or done much research, but I saw a radio on TV the other day that looks stock until you flip a switch. Then it's suddenly all digital and has most/all of the abilities of a modern stereo. Really liked it.
And I still need to install an antenna since at some point many years ago, my dad (for some unknown reason) remove the antenna and plugged the hole with an old TV channel knob and some kind of epoxy. LOL EDIT: Looked up some prices. Yeah, this mod will have to wait for a while
01-25-2015, 01:04 PM | #18 |
hammersmith, Are you running the digit signal through the AM Delco to the amp and the two speakers, or is it a separate system?
01-25-2015, 01:05 PM | #19 |
Flip
01-25-2015, 01:09 PM | #20 |
01-25-2015, 01:10 PM | #21 |
