01-22-2015, 04:55 PM | #1 |
87 R10 with 3/5 drop Can I run 255/70 15 tires?
I have a 87 R10 Custom Deluxe all original with ralley wheels. I want to do an inexpensive drop and not have to cut or modify the truck. I just put new 255 70 15 tires and was going to do a 2/4 drop but the rear scackles will require cutting the bed crossmember so was going to do a 3/5 flip bracket and coil. Has anyone ran this set up? Thanks
Never a failure, Always a lesson! 1968 Chevy SWB Fleetside ECE 4/6 327/350 1987 Chevy V20 Scottsdale 4X4 350/400 4.10 1987 Chevy Custom Deluxe SWB 305/7004R4 1991 Suburban Silverado V1500 4X4 350/700R4 2015 Chevy Crew Cab SWB (Daily Driver) 5.3 |
01-22-2015, 08:08 PM | #2 |
Re: 87 R10 with 3/5 drop Can I run 255/70 15 tires?
I'm running a similar setup with mine. My '87 has a 4/6 drop. It has a flip kit out back and 3" drop spindles with half a coil cut. I also took off the rear bump stop bracket and trimmed the lower control arms to clear the stock rallies. Also, the tires do rub on hard dips. Here is a pic of the truck.
01-22-2015, 08:12 PM | #3 |
01-23-2015, 12:35 AM | #4 | |
2018 Audi S5- wife's ride 1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511 1981 Chevy Silverado- in pieces 1964 Chevy c10 2017 Jeep Wrangler JKU |
01-23-2015, 02:17 PM | #5 |
255 70's 3" spindles and 1.5" drop springs..No problems at all. |
01-23-2017, 08:59 AM | #6 |
01-23-2017, 10:57 PM | #7 |
I believe I used a sawzall to cut the rivet heads off then used a air punch to knock them out. If not, a cut off tool will do.
