01-22-2015, 05:29 PM | #1 |
Airride Install Help (pic request)
Hello all, I'm installing my first air ride kit on my 70 c10 fleetside shortbed. Got my kit from EZ airride. I was wondering if you guys could maybe post some pics of where you mounted compressors and tanks. My kit came with a 7 gallon tank. Its says it's supposed to fit between the frame rails, but it looks a bit to big. Any help would be appreciated.
01-23-2015, 07:03 PM | #2 |
Re: Airride Install Help (pic request)
2 comps & 2 3gal tanks.....
01-24-2015, 11:40 AM | #3 |
That's what I eas thinkig. If I can get my 7 gallon to fit like that
01-29-2015, 05:33 PM | #4 |
SCOTI can you post a pic of your shock mounts?
01-29-2015, 06:30 PM | #5 |
I can take some better shots after work & post them tonight.
01-29-2015, 07:25 PM | #6 |
Don't be scared to fabricate a tank mount that centrally locates the tank in the middle of the frame and gives equi-distant line from tank to bag. Probably a good idea. My tank is in the middle of mine, but I am probably a bit more extreme than you are going.
Best Regards, Leon M. Instagram: @TheDirtyDianah
Bagged | 6.0L LS | T-56 (6-Speed Manual) | Turbo Burnout/Rolling Video: Chevy C10 Stepside 6.0L LSx & 6-Speed Manual |
01-30-2015, 11:59 AM | #7 |
Lower mounts are the original mounts cut off the rear end, the excess trimmed away, & then welded to the lower 4-bar mount. The upper mount is a standard C10/20/30 upper shock stud mounted to the upper bridge beam. I did have to machine the shaft to a smaller diameter to fit inside the sleeve on the Bilsteins since the sleeves are almost impossible to press out.
This arrangement allowed the slight side shift that resulted from using a Panhard bar.....
