1961 crewcab
bell housing
do any of you know if a big truck bell housing will bolt into a c/10?
I have a sbc in a 60 series bus and it has a brand new clutch/flywheel/pressure plate, just wondering if the whole unit might bolt in and clear the c/10 firewall and high hump. the bell housing has an access cover on the top that bolts on, and looks to use the same style lower mount on the cross member. I think it is a bigger flywheel, like a 12/13 inch? so it might not fit in a regular truck bell housing.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
| Bookmarks |
