Old 01-23-2015, 05:44 PM   #1
Johnie
Borg Warner Overdrive Rebuild Question
Hey yall. I've been lurking around here for a long time and have always found the answer to any questions without having to post. Except this time.
I need to get the shaft out of the tail section of my 3 speed overdrive to replace the drive shaft bushing. I think it is ready to remove but it must be a press fit. Before a couple of tons turn this into a pile of junk I wanted to see if anyone knows for sure there is no hidden clip or retainer. Thanks!
Johnie is offline   Reply With Quote
Old 01-23-2015, 07:25 PM   #2
ray_mcavoy
Re: Borg Warner Overdrive Rebuild Question
Welcome!
Yes, there is a hidden snap ring ... it's accessible after you remove a welch plug from the top of the overdrive case.
ray_mcavoy is offline   Reply With Quote
Old 01-23-2015, 09:01 PM   #3
Johnie
Hey Ray thanks a ton! I'd have ruined it for sure without the help.
Old 01-24-2015, 12:18 AM   #4
frankslagoon
The thing is kinda hard to get out. it's not just a piece a tin. I had to punch a hole in mine and pry it out. but it went back in just fine.
frankslagoon is offline   Reply With Quote
Old 01-24-2015, 08:37 PM   #5
Johnie
There is a step inside the hole that makes the plug a booger to drive out. I also had to put a hole in the plug and pry it out. Looks like it was replaced some time ago - that Dorman part number (P22S) isn't good anymore.
