![]() Join Date: Jun 2011
gas tank
im wanting to mount my gas tank under the bed and run the filler neck out the back and use a flip down license plate. can anyone tell me what tank to use? pics would be great as well.
Re: gas tank
ive heard of people using the first gen camaro tank
1967custom |
Old Duffer
![]() Join Date: Mar 2003
Re: gas tank
I'm assuming your plate is in the bumper? Are you sure you want to do this? How much lower must the tank be to allow a filler that low? And every time you accelerate a charge of fuel will gag the filler pipe? Heaven forbid, but what if you get rear-ended?
Sorry if I sound like an old fart, but this sounds a little dangerous to me. JMHO.
'68 Short C20 Flatbed Dually w/ 292 4bbl, Langdon cast headers, and WC T5 trans. '81 G10 Shorty Van "Good judgement comes from experience, and a lot of that comes from bad judgement." Will Rogers "Under promise, then over achieve." |
Re: gas tank
'69 Camaro has a soldered on filler neck that was behind the license plate. The '67-'68 carts used a hose that went to a filler that was centered in the taillight panel.
Search for "69 camaro gas tank install".
![]() Join Date: Jan 2013
Re: gas tank
If you look in Tech Tips 67SLIDER installed a 69 Camaro in his truck and has a detailed list of items he used. Very good info.
#6 | |
![]() Join Date: Dec 2010
Re: gas tank
http://67-72chevytrucks.com/vboard/s...ghlight=slider |
#7 | |
Re: gas tank
I probably have less than $250 and a nice Saturday in my setup |
#8 | |
![]() Join Date: Oct 2008
Re: gas tank
http://67-72chevytrucks.com/vboard/s...d.php?t=657551 Please post pics of your install. I am planning to do this soon... |
![]() Join Date: Aug 2007
Re: gas tank
#10 | |
Re: gas tank
69 suburban tanks work as well |
Re: gas tank
68 Suburban tanks work as well
Re: gas tank
thanks for the help guys that is exactly what I was looking for
#13 |
Re: gas tank
69 camaro is the tank you want. Definitely get the latching open plate. I want to say I bought one from a early 90s caprice. There's a cool tutorial on this site that I followed and it went in perfectly. One thing to think about, that no one mentions, as you can see from my avatar, my truck was lowered. I felt like I was on my knees to fill the tank. I decided I wanted a hitch, so I pulled my camaro tank and put in a blazer tank. I have air ride now so in theory you could lift the truck all the way up and fill it.
I stopped adding up how much I spend on my builds, it only makes me doubt my sanity knowing I've spent more than 9 times it's original value new.
