01-24-2015, 01:55 AM | #1 |
60-62 to a 63-72 suspension?
whats up guys.. im looking to buy a nice 60 apache panel truck and i got a question...i have no experience with the torsion bar setup..my question is this ..can i pull out the crossmember from the 60 and install a crossmember from a 71 including a-arms ,draglink,etc.i want the coil spring setup..any info would be much appreciated..
1966 C10 "Mary" 1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364 1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339 C10 Club Texas -HMIC |
01-24-2015, 02:58 AM | #2 |
60-66 Nut
Re: 60-62 to a 63-72 suspension?
Yes you can. Although I would use a '73-'87 front suspension. I believe there is a thread all about this written by Markeb01, located in the '60-'66 FAQ section.
01-24-2015, 05:02 AM | #3 |
Thanks brother...
01-24-2015, 01:13 PM | #4 | |
The 73-87 has thicker u bolts and holes to bolt up a sway bar. You can go up to 92 on the suburbans. |
