Old 01-24-2015, 09:50 AM   #1
fergi62
help, hidden fuel filler behind marker lamp
i know i have seen where people have taken the side marker light, hinged it, and put the fuel filler behind it when installing a rear mounted tank. my question is, is this a kit you can buy or is it a custom piece designed by the builder?would like to purchase one for a customers truck. i've seen the floor mount ones but this truck has a steel floor instead of the wood one. any help appreciated michael
for my yoke is easy and my burdens light. J.C. matthew 11:30
fergi62 is offline   Reply With Quote
Old 01-25-2015, 12:24 AM   #2
69pickupnyc
Re: help, hidden fuel filler door
I put in a 69 camaro gas tank and the filler cap is behind the rear license plate. You have to install a flip down bracket and the Tank is ease to install. Search 69 Camero gas tank on the forum. I had spelled Camaro wrong so make sure you spell it camero. I took some abuse but the instructions and pictures were great.
69pickupnyc is offline   Reply With Quote
Old 01-25-2015, 04:00 AM   #3
68shortwide
68shortwide's Avatar
lol 69 I remember searching for that when I first joined. Changed directions and doing a tail light fill. As far as Op goes, I think all of us on here have made our own version of it. Not sure if anyone makes a kit as everybody's needs and tank and ideas are different. Good luck though!
Jack
1968 swb on air
68shortwide is offline   Reply With Quote
Old 01-25-2015, 10:51 AM   #4
MSHax
MSHax's Avatar
I did the same thing, bought all the stuff for my 69 camaro tank, then changed my mind because I realized I wanted a hidden hitch. Did the blazer tank. The flip down plate still came in handy with my hitch though. If you don't plan on towing, the 69 camaro tank is pretty cool. Or you can do a bed fill and put in a trap door. Both of these are simple, if you're into something really cool, and have some extra time/money, the tail light fill is sweet. I've never done one, but I've seen a couple.
Should elaborate on the trap door, find a tank that doesn't have a filler neck, that way it's below the level of the metal floor. Aluminum seem to have the lowest filler.
I stopped adding up how much I spend on my builds, it only makes me doubt my sanity knowing I've spent more than 9 times it's original value new.
MSHax is offline   Reply With Quote
Old 01-25-2015, 12:38 PM   #5
barmanvarn
barmanvarn's Avatar
Subbed.
I was actually talking about this yesterday with my Dad and told him I'd really like to do the side marker mod at some point WAY down the road.
It'll likely be something I'll have to source out as I don't think I have the skills to pull it off myself.
Brian
'69 GMC C15
Inline 6, 230ci (possibly 250ci)
barmanvarn is offline   Reply With Quote
Old 01-29-2015, 02:47 AM   #6
lts70
1970 Daily Driver
lts70's Avatar
Tail light. I am going to try to copy this design
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance.
lts70 is offline   Reply With Quote
Old 01-29-2015, 02:48 AM   #7
lts70
1970 Daily Driver
lts70's Avatar
More
Old 01-29-2015, 02:49 AM   #8
lts70
1970 Daily Driver
lts70's Avatar
Old 01-29-2015, 02:50 AM   #9
lts70
1970 Daily Driver
lts70's Avatar
Old 01-29-2015, 02:51 AM   #10
lts70
1970 Daily Driver
lts70's Avatar
