Old 01-24-2015, 10:53 AM   #1
rs74
rs74's Avatar
Rebuild the 84 diesel 700r4 or update to newer?
I know that the earlier years of the 700r4 were not the best or at least that is what I have always heard. I need to either rebuild the diesel 700r4 that is in the truck or upgrade to a newer 700. So with that said. With the 6.2 is there really a need to put a newer one in? I am not sure what the newer 700's have that make it better over the older one. Just wondering if it is necessary to do so or if rebuilding the old one will be just fine. Also if a newer one is put in is it just a plug and play like the old one? I was thinking they were all TV cable operated and had a lockup plug on the side? I just want to make sure I have a good trans I can depend on.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 01-24-2015, 10:56 AM   #2
rs74
rs74's Avatar
Re: Rebuild the 84 diesel 700r4 or update to newer?
If updating to a newer one then how new can I go with the 6.2. I know the diesel trans have different converters and I think some kind of separator plates or something that the tranmission guy told me.
Roy
1987 R10 shortie
Old 01-24-2015, 05:24 PM   #3
Edahall
Get a newer unit and hope for the best because despite it being a stronger unit, the 6.2 still won't be easy on it. The older 700R4's were very weak behind the 6.2.
1990 ¾ ton 4x4 Chevy Suburban
-Cummins Diesel - 12 valve - factory rebuilt
-6 speed bullet proof manual transmission - NV5600
-Gear Vendors Overdrive - HX35 Holset Turbo
-NP205 iron transfer case
-3.73 gears -2" Lift
Edahall is offline   Reply With Quote
Old 01-24-2015, 06:30 PM   #4
rs74
rs74's Avatar
So how new can I go for one to hook right up? Don't have any problems rebuilding the one I have but if a newer updated trans if available even if it has to be rebuilt then I would rather go that way.
Roy
1987 R10 shortie
Old 01-24-2015, 10:58 PM   #5
craig113
You might want to check this link out...
http://transmissioncenter.net/competition.htm
84 K30 CC LB Fleet side 454/400/205/14 bolt Rebuilt 2200 miles
91 K15 Z71 SB 350/700r/241c/12 bolt 372k miles
96 K15 Sub 350/4L60/243c/10 bolt 333k miles
craig113 is offline   Reply With Quote
Old 01-24-2015, 11:57 PM   #6
Edahall
You want to get a 87 to 93 700r4 with the auxiliary valve body.
You'll also want a lower stall converter for diesel engines. Have the transmission shop open up the converter and braze the fins and fix the lock up mechanism that fails so easily.
Old 01-25-2015, 07:51 AM   #7
D13
D13's Avatar
Just buy the correct converter for an 87 with the 6.2.
Mine has 200, 000 miles on it, was rebuilt once.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 01-25-2015, 10:17 AM   #8
There were many upgrades made through the years on the 700r4. All I know is the one in my '85 diesel Jimmy with 4.10 3/4t axles and 315/75-16s works great. Don't know if it was ever rebuilt, but I've had it since '10. I tow, 4-wheel, and run it out hard. The axles came from a '91 diesel Suburban and the plan was to also swap-in the 4L80E/NP241, but never saw the need once I started driving it.
I don't what your use is with yours, but unless you can grab the best 700r4 for dirt cheap, I'd just rebuilt yours and roll with it.
Old 01-25-2015, 10:19 AM   #9
rs74
rs74's Avatar
It's just going to be a daily driver. I have my dually if I need to haul or pull anything.
Roy
1987 R10 shortie
Old 01-25-2015, 07:34 PM   #10
Jaysonb
Jaysonb's Avatar
I would guess that if you bring it to a guy that knows his stuff, he will be able to put beefier parts where they are needed.
Jaysonb is offline   Reply With Quote
