DIY Steering Wheel Resto
So after a lot of searching around for a steering wheel I really liked I came across the stock 1979 Corvette wheels from a build around here. Reproductions were running around $200 which was out of reach for me being a college student trying to build a full truck on internship money. So I found an old one on ebay for $10 and was hoping my upholster could cover it for cheap. Should have found out first that its time consuming so the price would be more than a reproduction.
Oh well, guess I'll have to give it a go. Just a preface, I haven't sewed since Home Ec in 7th grade. It's not that hard just time consuming. Heres the wheel when I got it. $25 shipped to the house. ![]() Cutting off the old crusty leather ![]() Beneath that was a layer of really hard crusty glue it seemed like. Hard but also brittle, if you kind of stab at it with a screwdriver and then scrape it using the side it comes off pretty quick. ![]() Here it is all cleaned up ![]() Now take the old cover and give yourself a rough outline of the pattern. After that take some measurements and clean up the template. Give yourself just a touch extra on the end to sew the ends together, but not too much as the piece should fit very snugly so it doesn't move around. You could also glue the sides for the middle seam back to give you a really clean seam, I didn't and I like the look. Either sew the ends together yourself or take it to someone who can stitch a straight line on a machine. The backsides should face outward so when you flip it back you don't see the stitch. Work the piece over the steering wheel doing your best to line up the spokes as it goes on because it wont be easy to slide once it's on. Soaking the leather in hot water will make it stretch too. Once its on check to make sure the spoke line up and there should just barely be a gap between the edges of the seam, this will get pulled together when you stitch it. By just barely i mean less than an 1/16th inch. Do the same along the sides of the spokes. Fold the ends at the spokes over and glue them. Remove the cover, flip it inside out, and mark your stitches on one side. I used 1/8th inch from the edge and 1/4 in spacing between stitches. You can play with this on test pieces to your liking, I also used thinner thread than usual as it matched the rest of my material and I liked the look. Again thicker will work depending on your taste. Once you have them laid out on once side, fold the cover lengthwise and use a large needle to poke holes through both sides of the leather. This ensures the stitches will be even on both sides. You'll have to do this in sections and it helps to weight down the fold to keep it flat. You can see my marks on the back side of this test run. ![]() Start at the top side of a spoke and loop the thread around the first set of holes twice. This is a baseball stitch, there's a few different types of stitch you can use. There's a few good youtube videos on this that can show the stitch better than I can. ![]() Continue this pattern carefully pulling it tight after each stitch and keeping it centered. Here is the final stitch and the final product. ![]() ![]() Now you can take pride in doing it yourself and for a total investment of $30 I'd say it turned out pretty nice. Also can help you bring your interior together just a little bit more than a plain reproduction. I hope this helps a few guys out at least. I learned a lot myself anyway. Build on
Pie rule. Everything takes 3.14 times longer than expected to complete -INSIDIOUS '86 |
| Bookmarks |
