Old 01-24-2015, 11:11 PM   #1
gt40racing
gt40racing's Avatar
2/4 Drop Complete C-20
Well I took the body lift off my 2WD C-20 and dropped it 2 inches in the front and 4 inches in the rear. Installed new shocks also. Definitely rides better. Previous owner definitely took some shortcuts..... Also installed new valve covers. Wondering if the 5 lug axle kits work on the C-20 trucks????
gt40racing is offline   Reply With Quote
Old 01-24-2015, 11:27 PM   #2
Stranny64
Stranny64's Avatar
Re: 2/4 Drop Complete C-20
Looking good!!! 😄
1968 Custom Camper C/20, rebuilt original 327 with 350 hp., turbo 400 with shift kit, factory AC truck, original patina rust free paint from Oregon, 2/4 lowering springs + 1" blocks, GM 2500 8 bolt rally's with dually center caps with Firestone Destination 245/75-R16's. (My 50th birthday present from my wife!!!)
Stranny64 is offline   Reply With Quote
Old 01-25-2015, 12:53 AM   #3
CST10
CST10's Avatar
Looks good. A 2/4 on a LWB looks fabulous.
MyToys:
Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles.
Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop.
Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ.
Member of the Louisiana Classic Truck Club, LCTC
Member of the Louisiana C10 Club
Member of the Baton Rouge Drifters Car Club
CST10 is offline   Reply With Quote
Old 01-25-2015, 01:13 AM   #4
gt40racing
gt40racing's Avatar
I am making myself a shop truck. Got to get some art work on the doors. Truck will be my weekend driver to car shows and car gatherings...
Old 01-25-2015, 07:50 AM   #5
Mike C
Mike C's Avatar
Keep the 8 lug. The 5 lug kits can be made to work on the front and new axle required for the back. If you work the truck, you will be glad for the HD rear axle.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 01-25-2015, 11:10 AM   #6
gt40racing
gt40racing's Avatar
Thanks! Was just debating the swap this morning. Think I am going to find me some disc brakes for the front and just continue making a solid reliable truck.
Old 01-25-2015, 12:38 PM   #7
seth7843
seth7843's Avatar
You should look at swapping a front end (suspension, brakes, crossmember, and steering components) from a 73-87 3/4 ton pickup or suburban. You will gain disc brakes, power steering, and a sway bar. Much cheaper than a disc upgrade kit and you only have to drill a few new holes in the frame.
seth7843 is offline   Reply With Quote
Old 01-25-2015, 01:49 PM   #8
Mike C
Mike C's Avatar
I did a disc swap on my '70 GMC Sierra Grande. I think ball joints are same or '73 and up work on the 3/4 ton trucks?
Double check, but I think this is an easier swap than the 1/2 ton. For my swap I bought a 70 that someone had already converted then swapped those parts onto my truck so I have no idea what the donor was.
Great mod though. I just finished disc swap on 69 short step I have. Did I mention I HATE front drums for a road vehicle?
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 01-25-2015, 02:34 PM   #9
northerngmc
northerngmc's Avatar
Very nice.
A few questions....
Did you replace coil springs for the drop?
Did you have to relocate the shock mounts?
Are the new shocks shorter?
How long did it take you to do the drop?
Nice wheels, what are they?
Blaine
59 GMC 9314 a.k.a. Whoopee
68 C20 50th Anniversary a.k.a. The Rat
http://www.flickr.com/photos/northerngmc/
http://www.members.tripod.com/P-wee/index_032.htm
1.61803 is one H of a lot better than 3.14159, no really it is!
northerngmc is offline   Reply With Quote
Old 01-25-2015, 04:18 PM   #10
gt40racing
gt40racing's Avatar
I replaced the coil springs with classic performance springs I ordered through Summit Racing.
The 4 inch drop did not require me to relocate but I heard 5 inch drop is where things start to change.
Yes the new shocks are shorter and also from CPP
Front took about 20 minutes each side... rear was about 30 total for both sides... not complicated at all.
The wheels are just regular circle track style black wheels. I got a set of stock 16's out for powdercoating right now...
Old 01-25-2015, 04:20 PM   #11
gt40racing
gt40racing's Avatar
I found me a 76 3/4 ton to harvest the front end parts...
Old 01-25-2015, 04:33 PM   #12
Mike C
Mike C's Avatar
Ball joints are different on Rock Auto, I just checked. Most likely can replace your 1970 ones with the 1976 ball joints. Otherwise, just swap in the control arms as well.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 01-25-2015, 04:43 PM   #13
gt40racing
gt40racing's Avatar
Thanks! Good info...
Old 01-25-2015, 04:47 PM   #14
northerngmc
Thanks, I didn't know CPP had C20 springs.
Blaine
Old 01-25-2015, 05:51 PM   #15
gt40racing
gt40racing's Avatar
I called them to verify the applications. The ride is awesome......
Old 01-25-2015, 06:03 PM   #16
gt40racing
gt40racing's Avatar
To be honest the suspension on my C-20 is not that much different than what was on my 69 C-10.....
Old 03-21-2015, 06:13 PM   #17
bmcvicker92
Did you have to C-Notch the frame?
bmcvicker92 is offline   Reply With Quote
Old 03-23-2015, 12:11 AM   #18
gt40racing
gt40racing's Avatar
C-Notch was not necessary. I heard when you get down to 5/6 inches in the back it is necessary...
Old 03-23-2015, 12:19 AM   #19
bmcvicker92
Thank you! That answer is all that was holding me back from doing the 2-4 drop on my own.
