Old 01-24-2015, 11:59 PM   #1
j.rigby15r
j.rigby15r's Avatar
oil pressure and sending unit.
Alright so I was tinkering with my 64 and the 350 under her hood. And got curious about oil pressure and all that stuff. I currently am using the stock mechanical oil pressure gauge. I had to replace the copper line with some nylon plastic tube from the block to the wall. At idol I get about 30 psi and usually 60 or more while driving. I feel this is good especially since if I have my valve covers of the oil shoots from the push rods all the way to the fender. Am I right in my assuming? Also I've been reading about oil pressure sending unit, do I have to have one with a mechanical gauge? If so why or why not?
j.rigby15r is offline   Reply With Quote
Old 01-25-2015, 12:21 AM   #2
Irishbleueyes
Re: oil pressure and sending unit.
Thats perfect oil pressure. You don't have to have the mech one. You can get elect unit and install sender for it. Stewart Warner makes a kit as do many others..
Irishbleueyes is offline   Reply With Quote
Old 01-25-2015, 12:44 PM   #3
Wrenchbender Ret
With a mech. gauge you don't need a sender unit unless you have a low pressure warning light or sometimes a electric heated choke will go through a pressure switch to prevent heating the choke when the engine is not running.
Wrenchbender Ret is offline   Reply With Quote
Old 01-25-2015, 12:51 PM   #4
j.rigby15r
j.rigby15r's Avatar
I didn't think I needed one but wanted to double check. Thanks for everyone's help.
