Washer bottle location
Was there different locations where the window washer bottle was mounted? I've seen some on the firewall as well as rad support.
#2 | |
The Older Generation
Re: Washer bottle location
Only place I've seen them on the '67-'72's is on the core support or drivers side inner fender. LockDoc
#3 | |
![]() Join Date: Sep 2010
AND . . . on the inside of the passenger's side fender when the truck was equipped with dual batteries from the factory, like this 70 C-20: . . . . |
![]() Join Date: May 2010
Based on my observations, I believe the bottle was mounted on the core support until sometime during the 1969 model year. I say that since that's where my original 69 produced during Dec., 1968 had it mounted, but many (most?) of the 69s I've seen had it on the left fender. The mounting brackets were also different as seen in the picture below. The one on the right is from my 69. I got the other from a later model in the junkyard. The extension on the rear of the one on the right allows the bottle to properly fit on the core support.
I was flipping through an assy manual I have and I seen a picture where it was mounted on the firewall near the fuse panel, I gotta find that page again.
Now that you mention it, I also remember seeing it there in the assembly manual. I think it was in the 69 section. However, I've never seen one actually located on the firewall.
All about them K’s
![]() Join Date: Jun 2014
My 72 cheyenne is on the passenger fender.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
