Old 08-22-2003, 11:21 PM   #1
rustyold69
student wrench turner
rustyold69's Avatar
bumpstops
i recently cut the front springs on my 69 c-10 and now the truck bottoms out on the bumpstop bracket on the lower control arm. I was going to cut it off but it looked like it also stopped the tires from turning too far. I am wondering how much farther the wheels would turn without this in place. Any help would be appreciated.
1969 Chevy C-10 with 250 L6
2002 GMC Sierra 2500 HD Duramax with banks six gun
rustyold69 is offline   Reply With Quote
Old 08-22-2003, 11:59 PM   #2
crazy longhorn
Fabricate till you "puke"
I cut the bumpstops off, & left the portion that was steering stop, then welded a pc of flatstock on the back to reinforce. For bumpstops, I drilled a hole in the a arm, & used traction bar "snubbers". crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
