![]() Join Date: Nov 2014
Help with rubber brake hoses POL lines to 73-87 calipers
Yesterday, I installed 67-72 POL disc brake line conversion kit and matching perportioning valve. Turns out the brake lines are larger than the original drum brake lines. I thought I was going to use 71-2 El Camino brake hoses but they are 3/8. So looks like I am looking for 7/16" female to connect to new hardlines,approx 12-13" long overall length with banjo end that will accept 10mm banjo bolt for later 84 calipers. Any suggestions as to what year make model will work? I don't want to use adapters or expen$ive ECE brake hoses.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO 71' Cheyenne C10 Hugger Orange on Saddle SWB Besides these two, too Many to count |
Re: Help with rubber brake hoses POL lines to 73-87 calipers
your front brake lines should be 3/16 dia on a disc brake system. I'm running elcamino hoses on my 67 with 76 calipers with 7/16 banjo.
you could run a 3/16"IF to 1/4"IF adapter fitting. it loo it looks like a dorman 072570BP should allow you to hook the el camino lines up
1967 C10 lwb two tone, 305 & rat fink style floor shifted 700r4, 20" steelies 2004 2500HD utility bed aka Brutus |
Jim thanks for the suggestion. I have not run any brake fluid thru the lines yet so I was hoping to return the El Camino hoses for another oe type hose. Found these on Speedways website but since I'm running the hardlines on the backside of the frame, I am concerned they would be too long at 15"?
are the replacement lines the 71-72 style?
do they come out in front or behind the crossmember and are the fittings on the hard lines where they attach to the brake hoses the same size on both sides? I think 71-72 hoses and hardlines are 3/16 on one side and 1/4 on the other. if that's the case you should be able to run 71-72 hoses
