01-25-2015, 02:30 PM | #1 |
2500 versus 2600 in rear for soft ride
I currently have 2500 bags with Schrader valves on the rear of my 66 C20. I need to get new shocks, since I don't really know how old mine are, and I'm pretty sure they are bottoming out occasionally. I relocated the shock mounts using the old mounts, like frizzlefry and ScotI did.
However, it does ride a little harsher than I was hoping for. Would the 2600's ride a little softer since they will have a little less pressure for the same ride height (I think)? FYI, I live in the mountains in Colorado (jst moved), and have 240 pounds of sand in the bed for traction. |
01-26-2015, 01:37 AM | #2 |
Re: 2500 versus 2600 in rear for soft ride
How much pressure is it requiring to achieve your ride height?
01-26-2015, 12:10 PM | #3 |
With the sand in the bed, it's at about 48-50 psi.
01-26-2015, 12:32 PM | #4 |
2600's would require less air psi for the same height as the 2500's. I wouldn't think the ~50psi is excessive. But, if you feel it is, the larger bag would require less psi.
I would do shocks first & make a decision after re-testing.
01-26-2015, 05:59 PM | #5 |
Yep, that's pretty much the same plan I was thinking since either way I need the shocks replaced. Thanks for the replies.
01-29-2015, 07:40 PM | #6 |
agreed. change shocks. I recommend the QA-1 Street Shock. They have 18 way adjustability for compression/rebound....awesome
....night and day over anything drop shock or Monroe can do
Best Regards, Leon M. Instagram: @TheDirtyDianah
Bagged | 6.0L LS | T-56 (6-Speed Manual) | Turbo Burnout/Rolling Video: Chevy C10 Stepside 6.0L LSx & 6-Speed Manual |
