01-25-2015, 04:56 PM | #1 |
installing a deck wiring
install a deck in my 84 Chevy truck that has a 3"led screen in it with back up camera;;ion deck wiring it says to run the white wire to parking brake switch;;at this time the parking brake assy has been removed from truck;;haven't put one back in yet;;so do I just ground the white wire from deck or do I run it to a keyed + feed or do I just leave it not hooked up until I install park brake assy? I'm assuming the white wire is to keep driver from watching dvd while driving so if park brake is on is only time dvd will work;;guess what I'm asking is if you have park brake set then is there 12 volts leaving switch or is it a ground leaving the switch when set?
01-27-2015, 02:38 PM | #2 |
Re: installing a deck wiring
thats a safety feature to make sure you cant watch a movie without the parking brake on. i had this with my excelon deck. ground it seperatly from the deck, no need to hook it up to the park brake switch
1967custom |
01-27-2015, 05:28 PM | #3 |
