WTB 68 GMC Drivers side headlight frame
My radiator support was hit in the drivers side headlight area, bending the bucket holding frame. Think it would be easier to remove and replace rather than trying to bend back into place.
I Would be interested in a 68 grill and upper trim piece as well |
Member #1049
Re: WTB 68 GMC Drivers side headlight frame
I have a pair that I removed years ago for "just in case".. $50.00 shipped
Cool! Are they from a 68 or are they all the same? PayPal work?
Member #1049
Not sure if all years are the same but I suspect they are, Yes these happen to be off of a 68,
Sending PM |
Roadtrip!
![]() Join Date: Feb 2003
Only differences i know of are the 67s and early 68s didn't have the dimple to aim the headlights with a screwdriver. Will still bolt on fine...
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
Just confirming, I.m looking for the frame that is welded to the radiator support which holds the headlight buckets. I will have to drill out spot welds to remove the double headlight frame, weld or bolt on and then replace the headlight buckets into the frame
Roadtrip!
Sorry, i thought you meant the bezel...
No problem, we'll get it figured out
Thanks Livrat, Paypal sent
![]() Join Date: Apr 2003
I have a good painted 68-70 grill and a good 67-68 top bar . $250 plus shipping. I can get pictures tomorrow if your interested.
Southern Parts, thanks for the offer, I'll have to look you up later when I replenish the trick budget a bit.
