01-25-2015, 06:47 PM | #1 |
using a vacume pump as an airbag compressor
I have a SSBC electric vacum pump and was wondering if there were anyway to some how use it as an air compressor for air bags?
01-26-2015, 02:57 AM | #2 |
Re: using a vacume pump as an airbag compressor
A vacuum sucks a compressor blows,I doubt you could change it over to work.I would sell it and use the money to buy a compressor,Some of our vendors on here have good deals.
01-26-2015, 07:52 AM | #3 |
The pump you have is a diaphragm type pump and they do a good job at making vacuum but not pressure. You will need to get a pump designed for making pressure.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
01-26-2015, 12:37 PM | #4 |
Never Ending Projects
Simple answer is no. One sucks, the other blows...
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
01-26-2015, 01:05 PM | #5 |
Thanks for all the answers. Please don't get mad at me for asking another one. I was just wondering because the pump has both a intake tube and an exit tube. Is there any way to test and see if it produces enough pump pressure?
01-26-2015, 01:28 PM | #6 |
Not any way it will make much pressure. The one we have at work will make 12 or thirteen at the most and then don't have the power to push the diaphragm up. Found that out when I hooked one up backwards. No where close to the 150 needed for an air ride system.
Jimmy
01-26-2015, 02:05 PM | #7 |
thanks
01-26-2015, 10:28 PM | #8 |
I have a pump at work capable of doing 26 in. Hg of vacuum and. 100 psi of pressure depending on how I plumb it. It was also $600, so I think I would rather have my $150 444c
01-27-2015, 07:48 AM | #9 |
Is that a DC pump? or is she plugged into the wall?
Jimmy
01-27-2015, 07:53 AM | #10 |
01-27-2015, 01:25 PM | #11 |
Figured it had to be. The DC stuff we have for vacuum does not have near the power to do that. Ac is another story.
Jimmy
01-29-2015, 07:42 PM | #12 |
you want to have something that can fill your tank between 150-200 psi. And not take 20 minutes to do it
Best Regards, Leon M. Instagram: @TheDirtyDianah
Bagged | 6.0L LS | T-56 (6-Speed Manual) | Turbo Burnout/Rolling Video: Chevy C10 Stepside 6.0L LSx & 6-Speed Manual |
