Old 01-25-2015, 07:04 PM   #1
paulbrgr9999
trans fluid check 350 with turbo hydromatic
Do I check the trans fluid when the engine is cold or hot? 350 with turbohydramatic automatic trans.
thanks
paulbrgr9999 is offline   Reply With Quote
Old 01-25-2015, 08:01 PM   #2
SS Tim
SS Tim's Avatar
Re: trans fluid check 350 with turbo hydromatic
Hot, idling in neutral. Check your owner's handbook for more information.
SS Tim is offline   Reply With Quote
Old 01-25-2015, 08:18 PM   #3
paulbrgr9999
Thank you!
Old 01-25-2015, 08:19 PM   #4
truckster
truckster's Avatar
Owner's handbook.
But yes, hot and idling in neutral (or park). And run it through the gear positions (P-R-N-D) if it's been sitting without being driven for a while.
DON'T OVERFILL! That's a bad thing to do. And realize that while the approximate fluid volume between lines on an oil dipstick is 1 quart, for the transmission it's 1 pint.
truckster is offline   Reply With Quote
