Old 01-25-2015, 07:58 PM   #1
77K10Silverado
77K10Silverado's Avatar
12 Bolt Rebuild Opinions Wanted
Just looking for suggestions on how you would rebuild my 12 bolt with GM locker from my 77 K10. Axle, bearing, and gear manufacture? Paint or powdercoat the housing? Thanks for any input!
77K10Silverado is offline   Reply With Quote
Old 01-25-2015, 10:42 PM   #2
77K10Silverado
Re: 12 Bolt Rebuild Opinions Wanted
I guess to generate some interest.. yukon or Moser axles?
Old 01-26-2015, 07:54 AM   #3
Jake Wade
Jake Wade's Avatar
Are you talking gears and all?
Jake Wade is offline   Reply With Quote
Old 01-26-2015, 09:21 AM   #4
77 ChevySport
Here is a picture of my 77 Shortbed 12 Bolt which is powder painted to 60%
gloss. All stock parts where used. Larry
77 ChevySport is offline   Reply With Quote
Old 01-26-2015, 09:46 AM   #5
andrewmp6
Depends if you want bigger tires and a lift or leave the truck stock.
andrewmp6 is offline   Reply With Quote
Old 01-26-2015, 10:05 AM   #6
MikeB
MikeB's Avatar
Is something wrong with the 12-bolt now? Do you know what gear ratio it has and what you need?
I've always had good support from Randy's Ring and Pinion. Their Yukon R+P gears are as quiet as OEM. And they can fix you up with everything needed for the job including Timken bearings.
Several years ago I bought a brand new pair of 12-bolt axles from Moser Engineering for $245. I suspect they cost more now, but even $300 is a reasonable price. Randy's sells axles, too.
Mike
1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress.
1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 01-26-2015, 10:55 AM   #7
77K10Silverado
Guys this is a stock restoration. 3.07 gears. I plan on redoing the axles, bearings and possibly the gears but they look real clean so I may not. Nothing's wrong other than needing fresh bearings. They look to be burned up. The axles look a little mared where they were ridding the shaft bearings..
Old 01-26-2015, 11:05 AM   #8
77K10Silverado
Old 01-26-2015, 11:08 AM   #9
77K10Silverado
Old 01-26-2015, 11:08 AM   #10
77K10Silverado
Old 01-26-2015, 12:42 PM   #11
68post
Yeah , you need new axles too.
Tom's Differentials Inc. also has good prices and quality axles and parts.
I'd be worried about gear whine reusing those gears , they'll need to be setup exactly as they came out to mesh into the same pattern.
Find your best local shop that specializes in rear axles and have them do the job - they'll also let you know if reusing them is OK.
If you're just doing a refresh and don't need to re-shim the diff or pinion, you should be fine !
68post is offline   Reply With Quote
Old 01-26-2015, 03:45 PM   #12
Jaysonb
Jaysonb's Avatar
Just a thought, they make bearing seal combos that scoot the bearing over, to ride on new metal. I found them on rock auto.
Jaysonb is offline   Reply With Quote
Old 01-26-2015, 06:08 PM   #13
77K10Silverado
Jaysonb, I have heard of these. I wonder if there is enough meat on the stick to be quiet. Thanks for the suggestions guys.
