Old 01-25-2015, 11:22 PM   #1
775stepside
Where can I get a short block for a 89 2wd
Like title says looking to buy a short block. Where would be a good place and just a replacement motor not something fancy. Might add aluminum heads
775stepside is offline   Reply With Quote
Old 01-26-2015, 12:28 AM   #2
775stepside
Re: Where can I get a short block for a 89 2wd
Will a gm goodwrench long block fit my 89? Says it goes up to 85 though?
Old 01-26-2015, 10:45 AM   #3
iluvmy72
I think you have to have a 88-90. I could be wrong but memory serves that to me.
iluvmy72 is offline   Reply With Quote
Old 01-26-2015, 01:47 PM   #4
775stepside
I know I have a 88-90 just curious if that would fit my truck. But looking for used engines in good shape any info on them would help thanks
Old 01-29-2015, 05:24 PM   #5
OutlawDrifter
it will fit physically, but there will be some differences like rear main seal and roller cam provisions.
1991 Z/28, 6.0L/T56
Instagram @aceshighspeedshop
Old 01-31-2015, 01:35 AM   #6
UKNOWME
UKNOWME's Avatar
I'm confused what you're asking here. GM makes a long block for an 89 as well as 85. 2 totally different engines though.
2018 Audi S5- wife's ride
1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511
1981 Chevy Silverado- in pieces
1964 Chevy c10
2017 Jeep Wrangler JKU
UKNOWME is offline   Reply With Quote
Old 01-31-2015, 04:05 AM   #7
775stepside
I was going off the summit racing website, only shows it's good up to 85
Old 01-31-2015, 11:46 AM   #8
UKNOWME
UKNOWME's Avatar
If you want a GM long block I'd suggest visiting your local GM dealer
1964 Chevy c10
Old 02-01-2015, 09:47 AM   #9
speedygonzales
speedygonzales's Avatar
http://www.crateenginedepot.com/57-L...270-P9450.aspx
But that does NOT beat this price because with CED you will have to pay freight
So you get it here.
http://www.summitracing.com/parts/nal-12520270
Don't ask them to match price because they only match delivered price which will be higher when you add freight.
You may be tempted to deal with unknown suppliers like those on Ebay or other sites. If those other sites are within 10%, it's not worth the risk of dealing with an unknown supplier. If there is ever a problem, you may never be able to get the unknown to fix it.
You never said what engine you had so I just assumed it was a 350 and I would highly suggest you not change to aluminum heads.
You're welcome
99 Z71 (98 body style)
Pride and joy
speedygonzales is offline   Reply With Quote
Old 02-01-2015, 12:06 PM   #10
UKNOWME
UKNOWME's Avatar
So you get it here.
You're welcome
But how does the warranty work through Summit?
1964 Chevy c10
Old 02-01-2015, 04:49 PM   #11
speedygonzales
Call them and ask them 800 230 3030
Pride and joy
Old 02-01-2015, 08:19 PM   #12
UKNOWME
UKNOWME's Avatar
I think I will just out of curiosity. I'm a service advisor for a GM dealer and I don't know what I'd do if someone came in with a summit receipt asking for warranty repairs.
1964 Chevy c10
Old 02-01-2015, 08:56 PM   #13
OutlawDrifter
what's wrong with aluminum heads? as long as you put a quality gasket in place, vortec aluminum heads are a great add on.
1991 Z/28, 6.0L/T56
Old 02-02-2015, 07:46 AM   #14
speedygonzales
Forget about the dissimilar expansion rates for the moment. Let's just deal with what you said about Vortec heads. He has earlier production that is NOT Vortec bolt pattern. In order for him to use Vortec heads, he would have to change the intake, throttle body, the entire fuel system and the ECM or switch to carburetor.
None of which he said he wanted to do.
The majority of the accessory system hangs off the heads and therefore the mounting holes need to be in the correct place. Who knows which will match what he needs.
Too many variables for me to recommend changing. Stick with the easy.
Then there is the expansion rate difference and the issue with getting gaskets to hold. None of this adds up to going thru the hassle. Sorry.
Couldn't you simply ask GM? After all the SB was made by them and you (kind of) work for them??????
Pride and joy
Old 02-02-2015, 09:30 AM   #15
OutlawDrifter
yes, the intake would have to change, they do make tbi vortec intakes, however. so really it's not that big of a deal. bolt on 40hp and better cooling attributes of aluminum. seems like win win to me.
i HAVE done this many times with great results. not that big of a deal!
1991 Z/28, 6.0L/T56
Old 02-02-2015, 04:51 PM   #16
speedygonzales
Had no idea
Had no idea they made a Vortec TBI manifold. Learn something every day.
Pride and joy
