6 lug torq thrust st or summit legend fitment
Hey guys I am very interested in the AR Torq-Thrust ST 6 lug / 6 spoke 20" or the Summit Legend 6 lug / 6 spoke 17" wheels and I was wondering if they fit and if some of you out there have them on can you post some pics? I am talking about these wheels http://www.summitracing.com/parts/ar...38nc/overview/ or http://www.summitracing.com/parts/sum-141-7883c0
Re: 6 lug torq thrust st or summit legend fitment
I like the torq thrust but 20" don't leave much rubber for cushioning the bumps.
MyToys: Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles. Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop. Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ. Member of the Louisiana Classic Truck Club, LCTC Member of the Louisiana C10 Club Member of the Baton Rouge Drifters Car Club |
I like the Summit 17" ones. I have a 70 C20, 6 lug
I rather the 17" for sidewall cushioning.
I have the 5 lug version of the Summit wheels on my truck. I have 235 55 17 front tires and 275 55 17 rears. Front rims are 17 x 8 4.5" backspace and rears are 17 x9 5". I have the wider 5 lug 71-72 rear on my shortbed and that's about a big a tire as will fit without mods.
I like the graphite color Summit ones. Been thinking of getting a set for my truck so I can switch the look.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
Thanks for the responses...WarMonger and Mike C did you have to modify the rims at all? I have heard some need to have the lug holes drilled out a bit.
I did NOT have to mod the lug holes, but I did have to open up the center hole of the rim a little to mount flush to the drums. Does that make sense?
Thanks again WarMonger! Yes it does make sense! That is actually what I have heard before...Were you able to do it yourself or did you take them to a shop?
Harbor freight die grinder and some burr bits. I had a buddy kept shooting the bits with wd40 while I was grinding so they would not get clogged up with the aluminum. It took about 10 minutes per wheel. I would grind a little, test fit, grind a little test. Do that about 6 times.
6 lug in general is a pain to find wheels for. The aftermarket 6 lug wheels are designed for the late model 6 lug trucks and not the early large center.
Wheel selection is why I converted to 5 lug. And with the 5 lug wheels there is absolutely zero mods needed. With the 9" rim in the back I needed the extra width of the 71-72 5 lug axle in order for the wheel/tire combo to fit.
