mini truck racer
Wide band or data logger
Looking into one of these . Maybe a LM-2 from innovate ? Any input or experiences ?
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
Re: Wide band or data logger
I have thrown two lm-2's in the trash. I have been using AEM since with out complaints.
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
mini truck racer
Are these just gauges or are they loggers . I also looked at the FAST analog style gauge . Mainly needing to monitor A/F ratios coming up .
Boosted Member
I'm with Super72...Innovate stuff is GARBAGE.
I also had good luck with AEM, and with the NTK/Holley EFI combo I'm running now.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2023 Ford Explorer ST - Twin Turbskis 2023 Ford F150 RCSB - Whipple Supercharged 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
meowMEOWmeowMEOW
Have a couple of Innovates as well, 1 only keeps cal if the moon is just right.
The higher end not-really-portable one works well, but its cumbersome as HELL to use. (its the size of a car phone with like 5 cables coming out of it). Had an AEM onboard wideband on my SRT4 worked great, and I have an Autometer onboard my truck right now. With HP tuners and my existing wideband, I can log to a laptop or just use the gauge as normal.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
I run the FAST dual O2 setup with record and playback capabilities, have never had a problem with it.
Speed is just a matter of money, question is how fast can you afford to go? 8.95@148.97mph all motor haven't tried bottle yet Sponsored by: Getz Oilfield Consulting Hard Candy Customs |
I have a modotek 2stage n20 controller (made by Daytona sensors) it has the ability to datalog things like afr, rpm, speed, week control a shift light etc. Daytona also makes wideband equipment.
meowMEOWmeowMEOW
Hehe if you got the money, why not? Full RacePak
![]() too rich for my blood
mini truck racer
I honestly thought about the racepack stuff , But my truck has the stock harness in it . With the dash your talking about a total rewire . Maybe next winter . I have a lonely Wally and need an Ironman next to it LOL .
Registered Truck Offender
I'm getting ready to pull all the electronics from the truck,, including a Edelbrock Quickdata with 2 Innovate wideband O2's out of the truck.
You want to datalog,,, I can fix you up. Right now I'm logging Engine RPM coolant temp oil temp EGT in #1 and #2 O2 on each bank Driveshaft RPM oil pressure fuel pressure I disabled the G meters in favor of monitoring Transbrake on/of (to key the data to a time slip) and throttle stop on/of As I remember there is 16 channels. If your really interested email; me and I'll send all the info BUT,, be aware... you HAVE TO HAVE a old craptop with a 9Pin comm port. I have not found one of the usb-9pin adapters 'yet' that works. Seems the MSD and Quickdata has some security crap that kills the USB adapters
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
meowMEOWmeowMEOW
You can run a version of the RacePak dash display off of just an OBD link. The benefit of it being modular is you can start small.
#12 | |
mini truck racer
Thinking that a Dyno session is the route for me . I was just wanting to log for the changes and then pull it all off .
#13 |
The AEM failsafe wideband is what I have and it data logs.
#14 |
mini truck racer
Actually this seems to be a good one . It keeps coming up .
| Bookmarks |
