01-26-2015, 10:03 PM | #1 |
Brake hose question
About to dive into the (lack of) brakes. As the truck is in another town, I have to turn to you folks for some help since I can't just walk outside and crawl under the truck.
Was on LMC getting ready to order new brake hoses, as I'm sure they ones on the truck need to be replaced. The front hoses came in a pair and the rear was a quantity of 1. Looking at the illustration, it looks like the rear has a line that runs into a "T" which feeds both rear brakes? Still appears to be 2 rear lines. Just wondering why LMC sells the front as a pair, but not so for the rear. Am I misunderstanding something? thanks
Brian '69 GMC C15 Inline 6, 230ci (possibly 250ci) |
01-26-2015, 10:07 PM | #2 |
Re: Brake hose question
The rear is hard lines.
Have you checked with your local parts store? I would start there WAY before LMC. I buy everything I can from the local parts store. After 45 years things have been changed on the truck. It's bad enough buying a part, realizing it doesn't fit, and having to drive 20 minutes to the parts store to figure it all out; I can't imagine having to ship something back and wait for a new part. For the most part LMC is a catalog company. They hire people that can answer phones and enter parts number into the sales software. Depending on which parts store you go to they may not be much better, but you can put your hands on the part before you pay for it. And there are some parts store that have good knowledgeable employees, if you find one of those spend everything you can there so they don't go away.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
01-26-2015, 10:13 PM | #3 |
I did try my local parts store first (always do), and they didn't carry the hoses I needed.
That's the only reason I resorted to online. I agree, if the need to return something arises, it's a major pain. Good info on the rear being hard lines as the catalog was saying there are hoses on the rear.
01-26-2015, 11:43 PM | #4 |
20' Daredevil (Ret)
The rear has hard lines to each brake, but there's also a single flex hose connecting the hard line on the frame to the junction fitting on the rear axle housing.
01-26-2015, 11:46 PM | #5 | |
Will get them ordered asap. Hope to get to dive into the brakes this weekend....assuming my radiator is repaired and I can sign off on the engine for the time being.
01-26-2015, 11:48 PM | #6 |
That brings up a question...
So, a single line feeds both rear brakes (via a "T" connection)? Does that necessitate some kind of trick when bleeding the rear brakes?
01-27-2015, 01:02 AM | #7 |
I just changed mine out and the rear hose does go to a T that goes to both wheels and the flex hose hooks to a clip With the fitting from the hose that comes from the front. ( hope that makes sense) I had to heat my rear flex hose at the 't' fitting to get it loose, it was on real tight. It didn't change anything as far as bleeding the rear brakes. I ordered my entire brake set as far as shoes,spring sets, wheel cylinders & the flex hoses from rock auto. Seemed pretty reasonable as far as price.
01-27-2015, 01:08 AM | #8 | |
I'd like to just go and order everything (as it'll likely be needed) but I've spent so much so far just getting the engine running, that I have to cut back a bit. Don't worry, I'm not scrimping on safety. Right now I'm just trying to get it so that I can drive it in and out of the shop on my property. It'll all be done up nice and safe before it gets near a road. As for the bleeding, I guess I'm just used to newer vehicles with 4 seperate brake lines. I just figured since a single line feeds the back, that standard bleed procedures wouldn't work. I found another post suggesting a gravity bleed.
01-27-2015, 02:23 AM | #9 |
20' Daredevil (Ret)
Freddo already answered so I'll just echo what he said -- bleed the rears just like you would any other system.
01-27-2015, 11:37 AM | #10 |
gotcha. thanks
01-27-2015, 01:18 PM | #11 |
This is from when I put all new lines on my truck. The nice shiny stainless hardlines connect to a brass Tee fitting, and the hose goes from the Tee up to the frame, where it connects to the hard line running all the way to the front.
When you get the hoses, I recommend getting new clips for them as well. Cheap insurance.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
01-27-2015, 01:27 PM | #12 |
I'll certainly be replacing everything at some point. Right now just replacing the hoses as I'm sure they are in poor state. Just picked up my radiator from the shop....not good news.
01-27-2015, 11:02 PM | #13 |
I got mine from CPP (Classic Performance Products) steel braided lines when I converted to front disc. Not cheap (100+) but should last forever.
02-04-2016, 09:50 PM | #14 | |
Got some 5/16" hose for trans cooler, that was $4.99 a foot!
1968 Long Bed 2016 Honda Civic Coupe EX-T ticket magnet |
02-04-2016, 10:12 PM | #15 |
Inlinetube.com is where I got mine. The complete line kits are preformed and the correct length. Just bolt it on. Very happy with their products that they sell.
