Old 01-26-2015, 10:18 PM   #1
king drake
Custom console needed.
Hello guys,I need help finding a full length custom console for my jimmy,Are there any good after market console out there,I would appreciate any help.
king drake is offline   Reply With Quote
Old 01-26-2015, 10:38 PM   #2
GMC-YA68
GMC-YA68's Avatar
Re: Custom console needed.
Nothing out there that is an aftermarket piece. You would have to build one.
-Keegan-
'72 Jimmy 4x4 - 5.3/4L65E/NP205 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=663780
GMC-YA68 is offline   Reply With Quote
Old 01-27-2015, 11:13 PM   #3
king drake
Thanks anyway,there might be someone out there,that can build a nice one,I will build one if I don't find one.
Old 02-16-2015, 10:42 PM   #4
king drake
Looking for a custom console builder.
Old 02-16-2015, 11:37 PM   #5
SS Tim
SS Tim's Avatar
Found these guys a couple of years ago. They have several models. Here is their original long, but there are others.
http://www.classictruckconsoles.com/...ucketseats.htm
http://www.classictruckconsoles.com/...etoverhead.htm
If you are wanting a Hickey or Con-Ferr metal style for a utility bucket, base Blazer things are a tougher. From what I understand the Hickey is being reproduced but the Con-Ferr with the seat back is not being repfoduced.
SS Tim is offline   Reply With Quote
Old 02-16-2015, 11:48 PM   #6
king drake
Thanks,I wil check them out.
Old 05-19-2015, 01:42 AM   #7
midunes
midunes's Avatar
I offer these on my website.
website www.hickeyoffroad.com
paypal hickeyoffroad@gmail.com
midunes is offline   Reply With Quote
Old 05-19-2015, 03:52 AM   #8
mcmlxix
Collector of Projects
mcmlxix's Avatar
I drew one up on a napkin and had my local waterjet guy cut and bend it... Its not finished. In the pics you will see that I didn't bend the front down and its not welded. I wanted to recess the e-brake handle but now I may change the whole design...
Rich
1972 K5 Blazer CST Click HERE
Old 05-19-2015, 08:31 AM   #9
bamachem
bamachem's Avatar
I built one. Nothing I found for sale was even close to what I wanted. Here's some pics:
Finished Product
Also finished out some speaker boxes and side panels for the rear seats too.
72 K5 Blazer - BCHWGN
bamachem is offline   Reply With Quote
Old 05-19-2015, 08:45 AM   #10
bamachem
bamachem's Avatar
Here's some details:
I wanted a full length console. Had to have some storage, at least two cup holders, and be home to (2) 6.5" speakers up by the firewall. Also, I don't like consoles that have hinged lids because the lid gets in the way when it's opened. I went with a sliding top on the storage compartment. Here's some of the preliminary sketches.
Construction Pics.
I rounded all the edges to get a better fit with the vinyl. I put a 1/16" butyl rubber pad under the vinyl. This is not only for padding and protection of the vinyl, but also for moisture protection for the MDF used to construct it. The bottom side got a coat of rubberized truck undercoating before the butyl rubber went on. No bare wood is touching the floor so it should be well protected from water.
Here's the back of the sliding top. I used a PERKO boat latch with lock to make the storage area secure. I'm eventually going to move this to one to the front for easier access to the lock, and either plug this hole or just install another latch and leave this one as-is.
Here's a shot of the butyl rubber pad before vinyl install.
The section are made so that there are no exposed screws. Every connection is hidden.
Old 05-19-2015, 10:52 AM   #11
mtully79
mtully79's Avatar
Great work, like the sliding top.
mtully79 is offline   Reply With Quote
Old 05-19-2015, 10:54 PM   #12
king drake
Thanks guys,I end up getting one from Classic trucks consoles,I'm going to add some things to it,wake it up a little bit.
Old 05-19-2015, 11:03 PM   #13
king drake
Bamachem,you did a great job on your console,you gave me couple ideas on my console,thanks.
