![]() Join Date: Dec 2014
Running coil overs, and coil springs?
I just bought the coilover kit from ride tech for the front of my 67. My budget just took a hit because I just had to put a trans in my Acadia. A $3000 hit!!! So for the rear of my truck I was thinking about buying the cpp rear suspension kit with 5" drop springs to save me some money. I've heard the 5" drop springs can be a bit mushy. Do you think the truck will handle weird with coil overs in the front and coil springs in the rear?
Re: Running coil overs, and coil springs?
I see no problem with that, I'd at least run Ridetechs shocks on the back. Obviously the full coilover setup would be the ultimate.
I'm in a similar situation. I'm running leafs in the back (with ridetech HQ shocks, which are awesome). And just got the full coilover setup for the front.
69 GMC shortbed Carbed LM4 - Manual VB TH350 - Gear Vendors OD |
it will be fine with coilovers in the front and the factory style coil springs and shocks in the rear. I would run a 3" spring with a 2" block instead of the 5" spring.
I'm running the old cpp coilover setup on the back of mine and I definitely prefer it to coils and shocks because of the adjustability. with the springs being available in 10# increments its easy to tailor the ride exactly to how you want it
1967 C10 lwb two tone, 305 & rat fink style floor shifted 700r4, 20" steelies 2004 2500HD utility bed aka Brutus |
I didn't know cpp made a coilover kit?
it's been discontinued for a while but they still come up for sale from time to time.
the CPP setup mounts the shocks off the back of the arms outside the frame
![]() Join Date: Mar 2014
Should be fine with coilovers in the front and springs in the rear, my 98 Toyota is set up that way and rides great.
"Sometimes I do serve as a good bad example. Glad to be of service." My Build Thread (1967 C10, lowered, EFI, daily truck): http://67-72chevytrucks.com/vboard/s...d.php?t=830809 |
