Old 08-23-2003, 03:50 AM   #1
greenhorn male
greenhorn male's Avatar
Question Use it or loose it?
I have these 15x10 wheels which have a serious negative offset (not sure if this is the correct terminology). The back of it says offset -50? I included pictures with measurements. The front measures is 6-3/4" and the rear is 3-1/2".
I have 33x12.50's and 15x8 ralley's on my 71 K10 with a 4" lift.
I like the looks of the ralley's but I'm not sure if 8" is wide enough for my tires.
1- Are the 15x8's wide enough for the 33x12.50 tires?
2- Would you use wheels with this offset? Why not?
3- Can you post pics of something similar that shows how much they stick out?
Should I use them or loose them?
Thanks! I'm posting this on the 4x4 board as well.
03 Tahoe
72 GMC Super Custom 2500 Custom Camper, my reliable workhorse. Dual gauged tanks, dual battery trays.
greenhorn male is offline   Reply With Quote
Old 08-23-2003, 03:51 AM   #2
greenhorn male
pic 2
Old 08-23-2003, 03:52 AM   #3
greenhorn male
pic 3 3-1/2" measurement
Old 08-23-2003, 07:16 AM   #4
blue_69
someday
blue_69's Avatar
My Blazer had 8 inch wide rims on it with 35x12.50x15 tires when i got it. I put on a set that are the same size tire but the rims a wider. I havent ever measured the ones that are on there but heres a pic of them.
Here is a pic of the ones that came on the truck the front tire is an oddball that didnt match the rest
jason
Click Here to search ebay for all 67-72 parts
My 72 CST blazer build
72 CST Blazer 4x4
67 2wd swb ( project onion crate )
86 4x4 lwb plow truck
40 x 60 foot barn to work on all this stuff
blue_69 is offline   Reply With Quote
Old 08-23-2003, 01:09 PM   #5
greenhorn male
Jason
Those wide rims don't look bad at all on your truck. What kind of lift do you have? Any problem rubbing on tight turns? Notice any difference in handling?
Old 08-23-2003, 01:20 PM   #6
LudwigTheMad
LudwigTheMad's Avatar
I have a similar set of Weld alm. rims....the 3 1/2 backspacing is to keep the corect backspacing for cars/trucks that originally had 7" rims (used alot on the 60's Vette's) so as long as you have the clearince up down you should be ok.
your not suposed to put anything wider that 10.5 on 7's and 11.5 on 8's, the reason is that you push the seal on the rim out and make it weaker, so if you do it, watch the big bumps......
That's right, I'm back in the game again. No it's not pink.....
1972 Blue and White Suburban.
LudwigTheMad is offline   Reply With Quote
Old 08-23-2003, 01:47 PM   #7
blue_69
someday
blue_69's Avatar
Re: Jason
i only drove it on the road once with the narrow rims so i really didnt notice if it handled different or not. All i have to compare it to is my daily driver which is a 03 Hyundai accent but i think for its age and size it handles pretty good. I dont know what kind of lift is in it I think its around 6 inches worth and i have not had any problems with rubbing but i have not had it off road where it would see some twisting. BTW if you are thinking of selling them rims i kinda like them.
jason
72 CST Blazer 4x4
Old 08-23-2003, 01:59 PM   #8
LudwigTheMad
hey blue 69
I am selling those alum rims I have...
same backspacing 3.5 but I forget if they are 10's or 8's Ill have to measure...
$200 for set of 4. Universal bolt pattern so will fit any 5 lug.
shipping shouldn't be too bad after all they are alm.
As soon as my friend brings my Dig. cam. back I'll post um on the parts board.
Old 08-23-2003, 06:15 PM   #9
blue_69
someday
blue_69's Avatar
Sorry Ludwig i need six lug but thanks for the reply
jason
72 CST Blazer 4x4
Old 08-23-2003, 07:18 PM   #10
greenhorn male
rims
Blue,
I'll try to test fit them with tires sometime next week, unless I get a lot of advise not to use them. I am waiting for a friend who said will sell me his 33's. I'd rather not remove the tires I have on right now. I'll let you know if I decide to get rid of them. They come with rear caps and front 4x4 caps.
Luis
