Old 01-27-2015, 02:07 PM   #1
72chevyrick
spindle
I have a 72 1/2..will the spindles from the 81 fit on my crossmember?
72chevyrick is offline   Reply With Quote
Old 01-27-2015, 05:03 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: spindle
Not without changing the upper ball joints and outer tie rods.
Keith
Convert to disc brakes.
Old 01-28-2015, 12:10 AM   #3
72chevyrick
Re: spindle
if you can give me any other advice it sure would be appreciated...
Old 01-28-2015, 03:58 AM   #4
andrewmp6
Re: spindle
Are you trying to change the truck over to a 5 lug?
andrewmp6 is offline   Reply With Quote
Old 01-28-2015, 07:41 AM   #5
lolife99
lolife99's Avatar
Re: spindle
The best advice,... buy 71-72 spindles.
71-72 trucks are already 5-lug.
Keith
Old 01-28-2015, 07:44 AM   #6
lolife99
lolife99's Avatar
Re: spindle
Lots of parts change info here for drum brake trucks and just compatability in general:
Keith
Old 01-28-2015, 10:03 AM   #7
72chevyrick
Re: spindle
I have a 5x5 bolt pattern.i need a 5x 4 3/4 bolt pattern..im trying to see what is innerchangable .i have the rims and tires all ready.guys are saying the 91 z28 rotor fits but only on 81-86 spindle.
Old 01-28-2015, 10:38 AM   #8
lolife99
lolife99's Avatar
Re: spindle
Correct.
But you have to use 81-87 LIGHT DUTY (Belltech 3200) drop spindles, or stock light duty (1" rotor style) oem spindles.
And 1992 Camaro 1LE rotors.
Might be cheaper to re-drill a set of HD rotors for your existing spindles,...
Keith
