Old 01-27-2015, 05:25 PM   #1
putnam00
putting in a factory a/c unit
I have a 71 c-10 non a/c truck but I want to put a/c in. I have my hands on 2 maybe 3 factory a/c units. I'm not running the factory engine, its an LT1, so I'll have to make a bracket for the compressor I have a top mount blazer ac compressor. what other things do I need to get this going I'd like to have it in before my Tour Nebraska the first part of june. I know I could go buy a aftermarket a/c and come with all the stuff, I just don't have $1400 bucks for a kit like that even though there cool as hell
putnam00 is offline   Reply With Quote
Old 01-27-2015, 05:48 PM   #2
leftybass209
leftybass209's Avatar
Re: putting in a factory a/c unit
The holes in the firewall don't match between ac and non-ac trucks. You'll have to address that if you want to use a factory ac unit.
Look here
http://67-72chevytrucks.com/vboard/s...d.php?t=419390
leftybass209 is offline   Reply With Quote
Old 01-27-2015, 05:58 PM   #3
Mike C
Mike C's Avatar
You will spend more money and have a less efficient system than buying a kit. Just save your pennies as long as it takes and go Vintage Air. (One of the next mods for my truck...)
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 01-27-2015, 06:03 PM   #4
putnam00
yes I know I'll have to cut my firewall, I have a factory a/c cab that I can use for a guide, but was also told the wiring harness was different
Old 01-27-2015, 06:05 PM   #5
putnam00
the one in charge says no way in hell have to use what I have
Old 01-27-2015, 06:07 PM   #6
Eddie H.
Eddie H.'s Avatar
It's a lot of work to put factory AC in a non ac truck, but it can be done. The cut outs in the firewall are all different, so that would need to modified, and you would also need to install the vacuum operated flapper valves in the plenum and kick panel vents, as well as cutting holes in the dash for the outlets.
"Negative people always seem to have a problem for every solution"
Eddie H. is offline   Reply With Quote
Old 01-27-2015, 06:32 PM   #7
Mike C
Mike C's Avatar
Beyond making it fit, you need to find good functioning evaporator, condensor, compressor, hoses...
I re-did the AC in my Jimmy back in '89. It had been broken since about 1980. My dad had broken an aluminum fitting. I put the one new hose on it along with a dryer, vacuumed it down and recharged. Worked great! For about a week... Then the high pressure line blew up from old age. Found a place to reubild the manifold with the muller on it. Vacuumed it down and recharged it. Worked great! For about a month... Clutch failed on the compressor. New clutch was $72 and the time and a rebuilt compressor $75. So I put the rebuild compressor on. Vacuumed it down. And it worked for a long time. I think it's working now actually, but it's such an ineffecient and antiquated system it never gets used. Just pulled the top off and left it off.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 01-27-2015, 10:29 PM   #8
mrein3
mrein3's Avatar
With all due respect to other posters, you can put in a factory system for WAY less than the money companies are getting for aftermarket kits. That $1400 is the starting price. On this very forum I have read posts where folks bought the kit and ended up dropping a bunch more coin on other stuff to make it work.
The factory system, when done right, is WAY colder than most anything out there. Let me put it this way. When I get out of one of my vehicles cooled by one of these systems properly charged with R12, my glasses fog up. That just doesn't happen with newer systems. (My Chevelles are both still full of R12. The truck is R134a - which though cold doesn't fog my glasses).
You can convert the factory system to run R134a. All you need to do is adjust the POA valve.
Do NOT eliminate the POA and install a cycling switch with the stock compressor. It wasn't designed for that.
I did this conversion myself and love it. I wrote it up a few years ago here:
http://67-72chevytrucks.com/vboard/s...d.php?t=478564
I hope this helps.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 01-28-2015, 12:29 AM   #9
1972RedNeck
1972RedNeck's Avatar
The kits don't have near as big of heater cores.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 01-28-2015, 01:32 AM   #10
leftybass209
I have to mostly agree with this. While it's a lot of work to retrofit factory AC, and it's really bulky and nearly an eyesore.... it sure as heck is cold! Picking up pieces used can help save on costs too.
Old 01-28-2015, 08:09 AM   #11
Mike C
Mike C's Avatar
I never pondered that. In my part of Texas the size of a heater core has never come up!
The factory system in my '70 GMC truck worked really well and the OP is talking trucks, but the same system in the Jimmy is too small.
If all the components are in good shape, you probably can do a factory system cheaper. But time is money and how much do you have? My experience is that a LOT of these components will fail to age, and that's when these trucks were HALF as old as they are now.
I'm sure you can make it work, just not sure when you factor in your time as well as parts that is will really be cheaper.
Since the LT1 is the powerplant it will be a compressor change. Already we have one major component that is not factory. Custom hoses will need to be made which isn't too bad. Realistically the rest of the system should be updated to the correct expansion valve and a larger condensor for the R134a.
I am a firm believer in recycling parts and factory parts are usually the best, but the OP needs to know at least some of the caveats...
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 01-28-2015, 10:18 AM   #12
putnam00
Well i have till june 5th to have it all in. Like i said i have my hands on a factory ac cab and 3 under dash units and 2 outer boxes. Eye sores under the hood aren't a big concern for me most people here are amazed I have a fuel injected lt1 under the hood
