Old 01-27-2015, 07:55 PM   #1
Layne
Gauge cluster
I have a '68 C20
It does not have the tach or vaccume gauge.
I'd like to have a tach for obvious reasons. What is the vaccume gauge used for?
Layne is offline   Reply With Quote
Old 01-27-2015, 08:05 PM   #2
ray_mcavoy
Re: Gauge cluster
Like SS Tim said in this post --> http://67-72chevytrucks.com/vboard/s...d.php?t=558552 the vacuum gauge was used in medium duty trucks with Hydrovac brake boosters.
And as also discussed in that thread, a vacuum gauge can be used as a fuel economy gauge but the size and placement of the factory gauge isn't well suited for that purpose.
ray_mcavoy is offline   Reply With Quote
Old 01-27-2015, 09:49 PM   #3
CST10
CST10's Avatar
Re: Gauge cluster
Ditto.
MyToys:
Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles.
Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop.
Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ.
Member of the Louisiana Classic Truck Club, LCTC
Member of the Louisiana C10 Club
Member of the Baton Rouge Drifters Car Club
CST10 is offline   Reply With Quote
Old 01-27-2015, 09:55 PM   #4
Layne
Re: Gauge cluster
If I put in a new gauge cluster, and include the tach, just as well have all the gauges filled.
I may try to just add a tach, and replace the dim lights.
Old 01-27-2015, 10:05 PM   #5
ElKotze
ElKotze's Avatar
Re: Gauge cluster
I replaced my lights with these:
https://www.superbrightleds.com/
Really like them.
ElKotze is offline   Reply With Quote
Old 01-27-2015, 10:49 PM   #6
FirstOwner69
FirstOwner69's Avatar
Re: Gauge cluster
If you are just looking to fill that vacant hole at the bottom, I think the most useful thing to put in there is a clock from a 73-87 (after about 1980 they were quartz). Not original, but useful.
FirstOwner69 is offline   Reply With Quote
Old 01-27-2015, 11:09 PM   #7
Wizo
Wizo's Avatar
Re: Gauge cluster
you can also contact TBONE1964 and get a volt meter conversion kit to replace that useless amp meter. They look like they should of been there all the time.
1970 3/4 ton long box GMC
!968 C10 short stepside (Papa's Old Lorry)
2006 2500 HD Silverado Duramax/Alison
Wizo is offline   Reply With Quote
Old 03-24-2015, 06:35 AM   #8
hotrod969
Re: Gauge cluster
ElKotze, are th leds you put in your instrument cluster "dimable"?
hotrod969 is offline   Reply With Quote
Old 03-24-2015, 08:34 AM   #9
ElKotze
ElKotze's Avatar
Re: Gauge cluster
HotRod, no they are not. I don't know if there are dimmable LED's.
