Old 01-28-2015, 04:21 PM   #1
Popcorn W
Popcorn W's Avatar
Steering column add U-joints question
For a steering column that's 2" off center (cowl to box) where I'd need to add 2 U-joints, would I need to also add a heim on the cut piece between the U-joints? Or would the 2 U-joints act okay together without one?
Popcorn W is offline   Reply With Quote
Old 01-28-2015, 06:31 PM   #2
octanejunkie
octanejunkie's Avatar
Re: Steering column add U-joints question
Using a heim joint on an intermediate shaft is common on some R&P installations.
My column and box have a smaller offset than yours and I'm using a double u-joint like this
http://www.summitracing.com/parts/brg-024918
Déjà vu. It's that feeling you get when you hit your thumb with the hammer a second time
'59 Chevy 3100 Stepside
octanejunkie is offline   Reply With Quote
Old 01-28-2015, 10:01 PM   #3
Popcorn W
Popcorn W's Avatar
Thanks. I actually saw that same double joint at Speedway Motors and it says it's good to correct up to 1" of offset.
Old 01-28-2015, 10:49 PM   #4
octanejunkie
I would call Borgeson for advice. They are pretty responsive
Old 01-29-2015, 05:18 PM   #5
Popcorn W
Popcorn W's Avatar
Just found this on Speedway Motor's site.
I didn't see this before.
It does say if you have MORE than two u-joints though.
Old 01-29-2015, 07:00 PM   #6
PGSigns
PGSigns's Avatar
We used this setup on a lot of drag cars. Where you need a heim for support depends a lot on the setup. Some we did needed it to support the end of the column when the distance between the two u-joints was short like 10 inches or less. Can you post a picture of your setup?
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 01-29-2015, 09:51 PM   #7
Popcorn W
Popcorn W's Avatar
Jimmy
I can, but there's not much to see really. I'm in the process of doing a 2" Z which puts the column shaft 2" off. I haven't cut the shaft yet. I just ordered two weld on U-joints and a 3/4" heim. I just thinking about where to cut. I think if i cut close to the firewall I may be able to avoid notching the upper control arm.
