01-28-2015, 09:40 PM | #1 |
Exhaust manifold... baffle?
This isn't moving for me. If I leave it stuck in this position, what will it cause? Any suggestions for fixing it? (inline 6 ~ 250)
'68 Chevy C10 '06 Saleen Mustang #725 (Convertible) '04 Infiniti G35 '01 Infiniti QX4 |
01-28-2015, 09:56 PM | #2 |
Re: Exhaust manifold... baffle?
I can't contribute too much, but to demonstrate what that causes, you can always shove a potato in your daily driver's tailpipe and grab a lawn chair
Use some penetrating oil and spray it over and over through the course of the day. If it still won't budge and you don't have it in the budget for a new manifold, I'd get a dremel up in there with a small cut off to remove that plate. |
01-28-2015, 10:22 PM | #3 |
It's a heat riser, your truck will run better if you can get it working. It heats your intake until your motor warms up.
01-28-2015, 10:56 PM | #4 |
Here's a link to the lubricant GM makes for the heat riser. Should be able to get it at a dealer.
http://www.qualityoneautoparts.com/s...C-Delco/Detail |
01-28-2015, 11:35 PM | #5 |
Soak it down with any spray lube, will smoke a little but will free up just fine.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
01-29-2015, 12:21 AM | #6 |
If you can't get it free, you can torch it out. It won't hurt anything not being there.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison |
01-29-2015, 12:05 PM | #7 |
I am a Referee of life.
The further north your are the more you need it. Since your sig says Ga. I would try to free it up and if it doesn't just remove it.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
