Old 01-28-2015, 11:17 PM   #1
Dirty 30
Dirty 30's Avatar
5 lug?
What does a guy have to do up front to swap to 5 lug wheels? I have a 1966
Dirty 30 is offline   Reply With Quote
Old 01-28-2015, 11:42 PM   #2
slepysal
slepysal's Avatar
Re: 5 lug?
The simple answer... spindle swap . Go to the FAQ and look up disc brake info. I don't think you can keep the drum brakes and have 5 lugs.
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 01-29-2015, 07:47 AM   #3
PGSigns
PGSigns's Avatar
Re: 5 lug?
The easy way is to do the 73 to 87 swap. It also gives you the better brakes.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 01-29-2015, 05:40 PM   #4
ljackson
ljackson's Avatar
Re: 5 lug?
some good reading here:
http://67-72chevytrucks.com/vboard/s...d.php?t=263983
http://67-72chevytrucks.com/vboard/s...d.php?t=367260
what I did:
http://67-72chevytrucks.com/vboard/s...d.php?t=453346
Father and son built. Driven daily since 2012. 283, 3 speed. Mostly original. '81 PS and disk front. Fuel tank relocate.
Maintenance, repairs and upgrades on his dime now.
http://zacks64longfleet.shutterfly.com/
Higher res. photos in my gallery.
ljackson is offline   Reply With Quote
Old 01-29-2015, 06:26 PM   #5
Cooper197
Cooper197's Avatar
Re: 5 lug?
I used a McGaughy disc brake/spindle kit from Summit. Worked like a charm and wasn't all that difficult.
Cooper197 is offline   Reply With Quote
Old 01-31-2015, 01:28 AM   #6
namloc
namloc's Avatar
Re: 5 lug?
Do the swap .Find a donor 73-87 c10.Freshen it up and install it.stronger,safer,more wheel option's.
The Snortin' Bull
namloc is offline   Reply With Quote
Old 01-31-2015, 09:34 AM   #7
fleetsidelarry
Senior Car Nut
fleetsidelarry's Avatar
Re: 5 lug?
add '71 and '72 to the list of donors (it probably says that in the links ljackson posted)
Larry
fleetsidelarry is offline   Reply With Quote
Old 03-01-2015, 02:10 PM   #8
txinliner
txinliner's Avatar
Re: 5 lug?
spindle swap is easy I went with belltech 73 to 87 c10 for the rear I sent the axles to moser for redrill
65c10 43,000 original miles ,230 stovebolt,powerglide,3" drop spidles 3" drop springs w/ half coil cut and 5 drop springs in back with 1 1/2 blocks... c notch soon to add hei offy 4 v intake and holley 390
txinliner is offline   Reply With Quote
Old 03-01-2015, 10:35 PM   #9
62 short step
62 short step's Avatar
Re: 5 lug?
What did Moser charge to redrill? If you don't mind me asking.
www.louisianaclassictruckclub.com
1965 c-10
86 chevy c/k 20
62 short step is offline   Reply With Quote
Old 03-02-2015, 01:33 AM   #10
AustinBelair
Re: 5 lug?
I bought a 73-87 setup and the CPP rear 5 lug kit
My mother is a recent cancer survivor and this truck build is for her
AustinBelair is offline   Reply With Quote
Old 03-03-2015, 01:47 PM   #11
cooperhw
cooperhw's Avatar
Re: 5 lug?
Easiest way I.M.O. is to buy a 73-87 1/2 ton pickup or suburban and pull the rear end and front suspension including the crossmember. Pull yours out and put this in. One day R&R.
I just did one on a 68 C30 1 ton out and in complete in one day. You can rebuild everything or nothing as you choose. My donor was in great shape so I chose to leave everything alone. Bolt it in and away you go. Drill a couple holes and elongate a couple. Easy Peasy.
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
Old 03-03-2015, 02:32 PM   #12
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: 5 lug?
Up front, drop spindles or spindles from any 71-87 1/2 ton truck. Spindles, new ball joints to fit you a-arms and an outer tie rod to fit your spindles.
Out back.....66 will have trailing arms which you will need to weld the mounts onto any new axle housing you get other than the 71/72 coils sprung 12 bolts ( good luck finding one of those!)
Your easiest option is to either purchase new axles in the 5 lug pattern OR pull your axles and take them to a race machine shop and have them re-drilled( take a 5 lug drum with you for surety)
Good luck!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
