Old 01-29-2015, 01:11 AM   #1
rs74
rs74's Avatar
How hard to take the side trim off
I want to start taking the trim off as some of it is already off and the other is in bad shape. What has already been taken off left behind like a white foam tape backing. Will a rubber wheel take that off or do I need to try to get that off before using the wheel. Is there any certain process I should use to take the trim off and get all the adhesive off so I can order new trim. Will the wheel hurt the paint any? That way if I don't get around to putting it on for a while then at least it will look presentable.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
